Author Topic: RadarIQ on Kickstarter  (Read 15608 times)
Offline thundertronics.comTopic starter
  • Country: hk
« on: November 23, 2021, 06:09:30 am »
Relatively interesting project. I see main challenge in maintaining an active community, with good working application examples. They probably should have designed antenna differently, at least changed RX spacing in elevation plane to increase unambiguous monopulse angle sensing. There are numerous commercial modules that copied AWR6843ISK evaluation kit antenna arrangement.
update 1: Some other modules using similar chipset, search for AWR6843 / IWR6843:
« Last Edit: December 01, 2021, 02:29:53 am by thundertronics.com »
The following users thanked this post: ivi_yak
Offline ivi_yak
Re: RadarIQ on Kickstarter
« Reply #2 on: December 15, 2022, 11:52:50 am »
watching on it, such interesting :-*
eevblog
Online Marco
« Reply #3 on: December 15, 2022, 07:13:25 pm »
Why not make full high resolution 2D phased arrays or reflect-arrays at this point? (Or transmissive equivalents of reflect arrays.) RF PIN diodes are cheap, Dishy did it.
Wassenaar?
« Last Edit: December 15, 2022, 07:18:10 pm by Marco »
The following users thanked this post: thundertronics.com
  • Country: hk
« Reply #4 on: January 16, 2023, 04:04:09 am »
I think that RadarIQ was an attempt to create a hobbyist friendly version of original TI's 60GHz evaluation board, certainly not an alternative to Echodyne or Metawave radars. Good attempt, but community is too small and there are no news on the project.
