Author Topic: UV Facemask - Indiegogo  (Read 4920 times)
Offline Dave3Topic starter
« on: February 06, 2021, 08:41:47 pm »
UV face mask on Indiegogo. 20,000 rpm vortex fan & UV light.
A few milliseconds of UV exposure is insufficient, and Nature Research indicates several are minutes required to deactivate airbourne coronavirus.
https://www.indiegogo.com/projects/uvmask-complete-protection-for-the-new-normal#/
https://www.nature.com/articles/s41598-020-67211-2
"Far-UVC light (222 nm) efficiently and safely inactivates airborne human coronaviruses"
Offline PeLa
Re: UV Facemask - Indiegogo
« Reply #1 on: February 06, 2021, 09:20:53 pm »
They need two pulsed 4th harmonic NdYag lasers and a pretty big power supply for it to work as desired. The laser head will have to be water cooled  ;D
The following users thanked this post: Dave3
Offline JohnnyMalaria
    • Enlighten Scientific LLC
« Reply #2 on: February 06, 2021, 10:32:00 pm »
What a waste of money.
Disposable surgical masks are good enough when combined with...commonsense .
The following users thanked this post: Dave3, E-Design
Online Kean
    • Kean Electronics
« Reply #3 on: February 07, 2021, 12:09:34 am »
This first funded on Kickstarter, and some people apparently have already received them.
https://www.kickstarter.com/projects/umsystems/uvmask-inactivate-9999-of-all-pathogens-and-air-pollutants/comments
Offline james_s
« Reply #4 on: February 07, 2021, 12:39:00 am »
I wonder how much ozone those UV lights produce? I wouldn't want to be breathing that in for long. No doubt a bunch of people who don't know any better will buy these things, they won't work, but most will be none the wiser.
Online Kean
    • Kean Electronics
« Reply #5 on: February 07, 2021, 12:46:48 am »
I'm very skeptical of this project, but they do appear to have put a lot of effort into it.
Ozone creation is mentioned in the (very lengthy) Kickstarter FAQ section.
https://www.kickstarter.com/projects/umsystems/uvmask-inactivate-9999-of-all-pathogens-and-air-pollutants/faqs
Online SiliconWizard
« Reply #6 on: February 21, 2021, 05:06:43 pm »
Shouldn't this go to the Dodgy tech section?
Offline daqq
  • Country: sk
    • My site
« Reply #7 on: February 21, 2021, 05:11:18 pm »
Sadly that's a fairly uncommon ingredient.
« Reply #8 on: February 21, 2021, 05:26:22 pm »
So putting a UV generator right in your face is the answer.
 :palm:
Offline Stray Electron
« Reply #9 on: February 22, 2021, 12:44:11 am »
 :palm:
   You bet! You can get face cancer instead of Covid!
Offline james_s
« Reply #10 on: February 22, 2021, 02:28:33 am »
I can only assume the UV light is contained to a chamber that the air passes through. I'm still skeptical of it working but hopefully they had the sense to prevent exposure.
Offline BrokenYugo
« Reply #11 on: February 22, 2021, 02:34:24 am »
You'll get the ozone no matter how the light is shielded, probably not healthy.
2 CFM is probably insufficient, as I recall 4 is usually specified as minimum for a tight mask with supplied air.
The thing I find funny about all this fancy mask business is if one is serious about not inhaling a single airborne disease particle (COVID or otherwise) 3M bayonet type respirators and P100 filters, or even surplus NATO thread gas masks and proper CBRN filters haven't been too hard to come by at reasonable prices for months now. Or throw together a PAPR for a few bucks more if you don't like shaving for proper seal, though IME people give you a wide enough berth that filtration efficiency isn't so critical if you're wearing a full face respirator of any sort in public.
« Reply #12 on: February 22, 2021, 04:20:50 pm »
I dunno what kind of sense they had, but such a contraption would have to be thoroughly tested for safety before ever being sold. That part should be real fun.
Offline Zero999
  • 0999
« Reply #13 on: February 22, 2021, 10:19:25 pm »
That's not true. Only the shortest of UV wavelengths produce ozone and if if doesn't produce and very short wave UV, there won't be any ozone.
Offline ogden
  • Country: lv
« Reply #14 on: February 22, 2021, 10:56:45 pm »
I wonder - how it is possible to UV-disinfect air using energy source which is contained in the mask? Main question here: for how long any certain volume of the air is irradiated by UV light of certain power. One may claim to "disinfect" 1m^3 of air using 1mW UV LED during 1 sec and tell that 1m^3 of the air did see UV radiation, thus it is sterile :D [disclaimer: it was speculative exaggregation]
