EDA => DIPtrace => Topic started by: Falcon69 on March 23, 2016, 09:19:00 pm
Title: Dual Mosfet. Transistor, Gate, etc. Split into two schematic drawings?
Post by: Falcon69 on March 23, 2016, 09:19:00 pm
Okay, as title says. Working with one IC that has, for ecample, two mosFETs in it.
Is there a way to make two schematic drawings, one for each mosFET, and then when the schematic is imported into Diptrace, it will combine those two schematic drawings into that same chip?
I could however see a problem with this, if I have more than one of those chips on the board.
Title: Re: Dual Mosfet. Transistor, Gate, etc. Split into two schematic drawings?
Post by: Galaxyrise on March 23, 2016, 09:30:46 pm
a single "component" can have multiple "parts".  You see that with a lot of the supplied two-channel op-amps that have three parts (one for each channel, and one for supply voltages.)
Post by: Falcon69 on March 23, 2016, 09:35:14 pm
okay, how is it done?
 and can EACH part be moved around individually on the Schematic being drawn? (out of component editor)
Post by: Falcon69 on March 23, 2016, 09:55:26 pm
NM. I figured it out!
Thank You galaxie. 'Multiple Parts" was the keywords I needed to search for on google.
It seems you use Component>Add New Part....and that inserts a new page. simply copy and paste from first page the same drawn mosfet, reassign the pins, and attach correctly to the attached pattern. Then, open schematic you are drawing, place part, and you can move the pieces around individually.  Nice!
Now I can do my schematics to look more manageable.  It labeled the part as, for example, Q12.1 and Q12.2.
Putting in a new SAME IC chip, it gets labeled as Q13.1 and Q13.2....and so on.
Nice little feature.
