Products => Dodgy Technology => Topic started by: cougercat on May 05, 2021, 07:17:56 pm
Is there any truth to the direction electrons flow thru a fusible link and does it matter? how about the color of the print on the fuse body? Please read the ad info from the link below. I's really comical.
https://www.synergisticresearch.com/fuses/orange-fuse/ (https://www.synergisticresearch.com/fuses/orange-fuse/)
Gezzzz. I guess I'll just stick to my fuses which cost less than $5.00 usd.
"Audiophile" is all you need to know about it.
It's a curious market; it's set up to not just allow but indeed encourage self delusion, and strictly discourages anything that might break the lie -- like double-blind testing. I guess, since the customers are generally fiendishly wealthy, one might find a certain justice in conning themletting them con themselves, but I wouldn't exactly call that a moral imperative...
Tim
2nd Stage Rev. 2.0 Molecular realignment process
Great, I cannot wait to get some of these fuses. I need to upgrade from these: https://www.ebay.de/itm/181509391782 (https://www.ebay.de/itm/181509391782)...They simply cannot be as good as they cost only 22€ / pc.
Jeeez! |O
Cheers,
THDplusN_bad
I am considering the ethical implications of this market as there must be enough idiots out there to actually sell this shit to them.
I already have this product in early development:
(https://i.imgur.com/AIrLJBK.jpg)
https://www.synergisticresearch.com/cables/coreuef/uef-black/ (https://www.synergisticresearch.com/cables/coreuef/uef-black/)
(https://i.imgur.com/VjNiMd6.jpg)
UEF Black Power Cable specifications:
Global MSRP
US $499.00/5ft
3 each 12 awg. SR Copper:
Dielectric: (EPDM) Ethylene Propylene
Connector Input US: 1 each Synergistic Research C07 Pure Copper
Connector Input Int'l: 1 each Synergistic Research C07 Pure Copper
Connector Output US: Synergistic Research C07 Pure Copper IEC 15 amp
Connector Output Int'l: Synergistic Research C07 Pure Copper IEC 15 amp
Build Notes:
Atmosphere Level 2 UEF Shielding:
Silver Solder: 4%
Hand build time: 2 hours
*Quantum Tunneling: Post Production process, 1 million volts are passed through finished cable providing a “canal” that allows electrons to pass more freely through conductor material and connection.
*5 day Burn-in: 2 step process
Hand crafted in our California factory
Voltage and current Rating:
US: 20amp/125v
(EU/AU/UK): 16amp/250v
Blue HC 10 Awg
$649.00/5ft
3 each 10 gauge SR Long-grain Copper Conductor
Ethylene Propylene Dielectric
1,000,000 volt Quantum Treatment
Treated connectors UEF with Graphene
Gold Plated SR G07 Connectors
Level 2 UEF treated conductors with Graphne
Blue Fuse conditioning process
Hand build time 2 hours
2 hours to build one of those?
Don't those two statements above contradict one another or are they "burn't in" twice?
I was expecting to find something like this at the bottom of the page:
Frequently asked questions.
Q: Are fuses directional?
A: Yes, fuses are directional. Electricity should flow from the left to the right when you view the fuse. If you do not know the direction of flow you should listen to the fuse inserted in both directions. One direction will sound more detailed. This is the correct way.
Q: Do fuses have a burn in period?
A: Yes, most products have a settling in period. The first 200-300 hours of use are the most crucial.
I think they are upside down.
Burn in for audiophiles only consists of music playing, if you want to "burn-in" something with DC or even a sine wave, they don't consider it good enough.
But yeah with 1 million volts I'm surprised the cable doesn't physically burn to a crisp.
This to me looks ugly, untidy and way over the top:
https://www.synergisticresearch.com/cables/srx-cables/srx-sc/ (https://www.synergisticresearch.com/cables/srx-cables/srx-sc/)
(https://i.imgur.com/WWUCev9.jpg)
SRX Speaker Cable specifications:
MSRP
$29,995 / 8ft.
Geometry
Isolated 99.9999% pure silver geometries
Construction: Each pair of Synergistic Research SRX speaker cables are made from 20 separate geometries - 8 each 14 awg 99.9999% Pure Silver Air Strings, 8 each 99.9999% Pure Silver mono-filament Air Strings, and 4 each 4th Gen-Tricon conductors.
Dimensions: Standard 8 ft. lengths. Additional length built to order.
8 each 14awg 99.9999% Pure Silver Air Sting
Silver Air Strings: 99.9999% pure monocrystal silver conductor
Dielectric: Air (sealed)
Shielding: UEF Ground Plane Technology
8 each 2nd Gen 99.9999% Pure Silver Mono-filament Air Sting
4 each 4th Gen-Tricon:
Silver Copper Matrix: Monocrystal conductors
Dielectric: PTFE
Geometry: Tri-axial
Listened to determine signal direction before build
8 each UEF Cell: 99.9995% Pure Silver Ribbons/Copper with UEF
Teflon dielectric
Multi conductor Silver/Copper
Gold plated 2.5mm tuning circuit connector
Shielding : UEF Active Shielding 3rd generation,
Point to Point Wiring
WBT Silver Solder 4%
UEF Spacers/Elevators with built in HFT:
Each 8ft SRX speaker cable pair has 8 Carbon Fiber UEF Elevators with HFTs and 20 Carbon Fiber spacers
Quantum Tunneling: Custom
5 Day burn in : 3 Step process
4 each Gold SR25 UEF Tuning Passive Module: Optional voicing for increased warmth, liquidity
4 each Silver SR25 UEF Tuning Passive Module: Optional voicing for maximum information and refinement.
SR BoFa Banana and SR Gold Spade Connectors:
Build Notes:
Individual EXP Isolated cable geometries for improved vibrational isolation
52 point-to-point hand soldered connections
SRX UEF Matrix Shielding: 2 different UEF coatings with Graphene are applied to UEF Cell, connectors and cabling and ground significantly reducing the noise floor and allowing a purer signal to transfer with less grain providing more warmth and detail. The conductors and UEF Cell also benefit from dampening effect that UEF provides
4 Termination for SRX tuning Module (Silver and Gold)
WBT Silver Solder: 4%
Hand build time: 15 hours
Quantum Tunneling: After the cable is completely assembled all connections and cabling are treated with 1,000,000 volts of electricity at specific frequencies and pulse modulations, creating a canal in the conductor material and contact points at the molecular level that allows electrons to flow more freely. This allows the maximum amount of low level information through the conductors and provides for the highest amount of realism in your music
Secondary UEF Blue Treatment originally developed for SR Blue Fuses
5-day Burn In: 2 step process
100% Hand Crafted in our California factory
I see some stuff on that list repeated twice.
Also check out their award:
https://www.synergisticresearch.com/wp-content/uploads/2019/12/PF2019WC_SRX_Power.jpg (https://www.synergisticresearch.com/wp-content/uploads/2019/12/PF2019WC_SRX_Power.jpg)
(https://i.imgur.com/yLnDPgT.jpg)
PF Writer's Choice Award, 2019
On behalf of the creative community Aat Postitive *Feedback,and in recognition of significant contributions to the audio arts *2019,this award is hereby presented to**
Synergistic Research for their SRX Power Cord
in order to enourage further excellence in
the fine *audio,to the greater good of all who
love it.
November *16,2019 A.D.
PF
Posi+ive-feedback
David *W.Robinson,Editor-in-chief David *Clark,Managing Editor
*typo/no spaces?
** Is there suppose to be a :?
Are those mistakes I am seeing?
"Audio arts", I wonder if the whole thing is just art to them, the prettier the art looks the better it is going to sound to the audiphool.
You missed the most important feature:
SRX speaker cables are an exploded geometry with ten individual pure silver cables running in parallel separated by carbon fiber discs to eliminate cross-talk between conductors.
Apparently, with:
with Silver Matrix Conductors in a Teflon dialectic
Some Teflon! It can differentiate between the true signal and the rest of it. Clever.
Geez, I've spent my life working on projects to pay my bills, but now know that I've defiantly been in the wrong business. A friend of mine has bought into this fuse idea and has just plunked down $1200.00 for a pair of 12AU7 tubes. You know, the tubes that used to be used in most all amps of that time. We used to use these tubes for target practice in my younger days. He really insists that his sound quality is much better with his super expensive "directional" speaker cables too. Such is life.
:-DD :-DD
Not that hard to have music at a high voltage.
https://www.youtube.com/watch?v=nH-3TdWI-yI (https://www.youtube.com/watch?v=nH-3TdWI-yI)
I suppose if you wanted to market the cable as "high voltage burned in", you could suspend it in the air on nonconductive ropes and connect all conductors at one end to the Tesla coil and provide a discharge path at the other end.
hey quick question.
Why do laptop PSUs have that mains connector and not a ordinary IEC one?
I can't believe half these things are not some scam to launder money
What do you mean? All mine have IEC connectors... :)
https://en.wikipedia.org/wiki/IEC_60320
Tim
There is more than one IEC. ;D
Anyway. The Orange fuse has graphene. So, what's not to like?
If it's a quantum fuse, does that mean it's simultaneously blown and intact?
Probably.
It's Schrödinger's fuse.
It simultaneously conducts and it doesn't, but you will never know until you pass an over current and blow it up.
MSRP
$29,995 / 8ft.
Wow. That's 30k USD if I read it correctly. I'd really like to see a review of these from Dave Jones - pretty, please. :palm:
Cheers,
THDplusN_bad
Much more intelligent discussion on the topic of fuses, and their potential to affect the sound of an amplifier:
https://www.avforums.com/threads/audiophile-fuses.2348393/ (https://www.avforums.com/threads/audiophile-fuses.2348393/)
That's so that the electrons travelling in the wrong direction fall out, and don't distort the sound.
You’re hired as VP of marketing :-DD
hey quick question.
You mean the "cloverleaf" shaped one, not the ordinary "jug plug"?
More to the point, why on earth do they use those bloody useless "barrel connectors" for the low voltage side, instead of a plain old 2 pin rectangular connector like CB radios & the like used to use?
It's not that they need a jack which switches, as charge/not charge is all done electronically these days.
hey quick question.
The same reason figure 8 is used on metal-chassis appliances: it's cheaper. Mickey-mouse/cloverleaf/C5/C6 IEC cables only need to use wire rated to 2.5A, not 10A.
Do you have a pic of the rectangular connector you're reffering to? I think I've seen lots over the years, including ones that take mains instead of LVDC.
I know there are some standards from the 1990's about round barrel connectors for power (https://en.wikipedia.org/wiki/EIAJ_connector), not sure if there is more history behind that and standardisation of them.
One benefit: don't have to look when plugging them in, very easy to do by feel and rotation doesn't matter.
hey quick question.
Do you mean these?
(https://uk.farnell.com/productimages/standard/en_GB/2759892-40.jpg)
If they're so freaked out about mains power and the AC to DC power supply, why not design all the audiophool stuff for DC power? Power it all from a big battery bank. Ultra pure DC power. For all the money they pay for quacky power wiring you could probably get a decent bank of pure DC and just let the damn thing re-charge overnight.
:-DD
:-DD
But those DC electrons wouldn't be pure DC. They were once AC. It would require yet more audiophoolery stuff to replace every tainted AC electron with a pure, sonically perfect DC electron.
Back when digital cameras were new and very expensive, a colleague borrowed the company's highest resolution device - 640 x 480 (!) - for the weekend. He came back in on Monday with his tail between his legs. He said he thought the different sizes of barrel and pin were always keyed to the voltage / polarity, so he merrily plugged 12V the wrong way round into a 3V (or whatever) port. Naturally, this provided all the opportunity the magic smoke needed to make its escape.
I don't recall the aftermath. Both he and the then-boss passed away some years ago. But not, I might add, as a direct result of polarity / voltage errors.
But wot about the noise from the chemical reaction in the battery ,that will cause audio distortion.Of course i can sell you a device in a fetching black box to cut down the noise,for a price.
:-DD
So basically giant AirPods? :-DD
hey quick question.
The ones I'm thinking of were used in some CBs (not all), & from memory, a "standalone" car cassette player I had a few years before that.
They were definitely rectangular, with, from memory, a narrow keyway one one side, different pin spacing, & smaller pins compared to the "binocular" type connectors used on electric shavers.
Some ham radios used different 12v connectors which you could butcher the shaver ones to fit, but hams were smart enough to cut the mains plug off before they used them.
The one AVGresponding shows would be OK, too, but maybe a tad bulky.
You often have to wiggle them to make sure they are connecting, though, & the jack inside the laptop is incredibly flimsy.
Yaesu, for some reason, delighted in having the positive on the barrel outside for their handheld & portable radios.
This would be OK, if they are operating from, or being charged by, a power supply at home, but a bit problematical if used in a car.
My old FT290R was, apart from being a bit low on output power, ideal as a mobile, as well as a portable transceiver.
The problem was, if you accidently dropped the lead in the usual negative earth car, it would perversely not fall on plastic or carpet, but seek out any bare metal, delivering a nice "zap", scaring the living bejabbers out of me, apart from sometimes blowing a car fuse, or if not, scarring a nice piece of metal trim.
Every audiophile has got to have one of these nylon UFE receptacles that can be had for under 5 bucks at any big box store. One can tell the super quality difference between the orange, blue and black ones. Just ask them.
https://www.synergisticresearch.com/power/accessories/uef-black-duplex/ (https://www.synergisticresearch.com/power/accessories/uef-black-duplex/)
Here they are $199.99. I must be missing something here.
I have some of those PTFE cables, got them for free, so took them apart and used the individual cores to make test leads. Works well for that, as the resistance is low, and if you have an oopsie and overload them they just get hot, and nothing else, though you probably will be replacing the banana connector on the end, as it likely has melted.
Teflon or PTFE actually will sustain a flame once it starts burning. Try lighting some Teflon pipe tape, but keep away from the fumes. I've heard that Teflon emits Fluorine, which is harmful.
|O |O
Elemental fluorine isn't so much of a hazard (as there's plenty of carbon for it to stick to already) as the decomposition products, including lovely chemicals like PFOA (perfluorooctanoic acid -- an 8-carbon unit of former-PTFE with an organic acid group on the end). Lots of carcinogens in there.
Y'know, I wonder... I wouldn't be surprised if the safest, most thorough way to dispose of PTFE is to incinerate it -- very hot, in the presence of steam, yielding HF and CO2.
...Ah and yep, it is indeed fine, in fact it doesn't even need super high temperatures to do it:
https://www.gore-tex.com/sites/default/files/docs/Chemosphere_Incineration%20Study_Executive-Summary%20(002).pdf (https://www.gore-tex.com/sites/default/files/docs/Chemosphere_Incineration%20Study_Executive-Summary%20(002).pdf)
I mean, 1000C is a good bit more than your average charcoal grill, but it's pretty ordinary for enclosed fires and industrial processes. That's a typical kiln temperature for example.
Tim
Common for a lot of medical single use consumables to have PTFE as a lining or component in them, because of the biocompatability of inert PTFE with the body. As all is incinerated the PTFE will be burned as well, another good reason why you to not want to live downwind of an incinerator. The other common disposal method is to simply bury it, where it will survive for centuries, along with glass and ceramics.
That Thread was an excellent read.
And i like that the poster stuck to his guns.
In conclusion, i would say: Make something crappy enough, and it *will* have an effect. A negative one.
But solid standard construction is apparently more than enough.
I've no doubt that if I passed 1 million volts thru a finished cable, I would instantly find it's time to make a replacement one.
Where on earth do they get a million volts from anyway ?
Does anyone believe they have the required 3 story tall transformer needed to generate such voltages ?
Maybe Doc Brown hangs the finished cables from a clock tower during a storm :-DD
Marx generators, Vaan De Graff's, Tesla coils, all can generate tremendous voltage. They didn't say it was continuous either, or at how much current.
isnt that a cheap diode?
BTW electrons do not flow.
When the electrons flow through the battery they gain energy, but when they flow through the bulb they lose energy as it is converted to other forms like light and heat.
https://www.physics.uoguelph.ca/electron-flow (https://www.physics.uoguelph.ca/electron-flow)
A common misonception. its way of visualuisng things but its quite untrue. Current is defined as the rate of flow of charge not yellow balls! Think of the electons surrounding atoms in a conductor as a bucket brigade for charge. One of these electrons picks up some charge which is picked off by the next and so on.
It more like pushing on the end of a rod. The force is tranmitted but the rod remains unchanged. It more complicated than that of course.
Only few electrons in a wire are actually moving at all. The ones that do move at a snails pace, or less.
The false idea that electrons flow is so widely regurgited that its taken as physical fact -it is not, its an analogy thats a bit better than the water one.
This idea seems to be deeply upsetting for some, not least to vacuum tube enthusiasts. Its the charge created by the hot cathode that is acclerated to the anode not the electons themselves running about. A hot cathode does the same job as a cold cathode. The heating allows us to use a much smaller cathode area to obtain the same effect as a cold one.
So the "charge" from the hot cathode in a Pentode valve impacts the anode with sufficient force that it knocks off some secondary "charges" that are collected by the [Edit:screen suppressor] grid, preventing the characteristic Tetrode kink?
Do "charges" have mass then? :-\
P.S. How do the "charges" in an X-Ray tube work? Genuinely curious.
What's wrong with the hydraulic analogy? When one understands atomic theory, one knows that liquid water is composed of *illions of molecules banging around at about 1500 m/s. Almost any flow rate you'll encounter, is a small fraction of this, and so we can make the same observation that pressure is transmitted from molecules bumping into each other, not so much the overall flow; and that the dominant motion is internal and random.
It's an uninteresting argument, and worst of all, doesn't illuminate anything to the reader. So what if it's mostly random motion, does that just mean it's getting hot or something? No, that's just thermal energy. Oh, and it's too small to see. Well so what. (Well, yes actually, it is effectively the origin of resistance. But proving it gives a proportional [Ohm's] law, is much harder. Or understanding the sequence of facts that are required to derive such a law -- that's whole-ass statistical mechanics, arguably. :o )
What's interesting is when the charges are "free" to flow, i.e. in free space under the influence of fields, ballistically, rather than damped out by random motions. Then we find a V^(3/2) power (Child-Langmuir) law, we find mass and we find everything that we expect as a consequence from that (i.e. all the electron-resonant microwave tubes).
Cool fact, the electrode (especially grid) capacitance of a late model vacuum tube about doubles going from cold, to hot and biased. The cathode electron cloud expands and contracts in response to the grid's electric field, giving and taking energy from the electric field; mass is a conservative property, and so too is the manifestation at the electrode -- reactance. If some of the cloud happens to leave, however, its initial energy is carried off with it -- beam current causes loss, manifest as grid conductance/resistance, however you like to express it. This extends to subsequent electrodes, too: the screen, suppressor, etc. experience a small transconductance, from grid to grid, even when the later grid is reverse-biased (as suppressor or pentagrid control 2). The reciprocal is not true, however: the beam acts as a conveyor belt, breaking symmetry, and thus this is a nonreciprocal property (gm(1-3) nonzero but gm(3-1) zero, or, effectively just plain old interelectrode capacitance because it's not going to be |zero| in practice).
This property is even used to advantage in some types: dual-control pentodes (6HZ6 etc.) and sheet pentodes (6BN6 etc.) can be used for FM discriminator service, where g3 is simply tied to GND through a high impedance parallel LC tank. gm13 is quite small (10s umho?) so the impedance needs to be quite high (100s kohm), but given this, it resonates sympathetically with the driven source. g3 voltage acts to gate the output (plate) current, so the plate current ends up PWM with respect to the phase shift between source and resonant tank. And that phase shift is proportional to frequency shift vs. resonance (for small enough changes in frequency -- for commercial WBFM, the Q needs to be fairly low; like I said, high impedance tank!).
Ballistic transport is also possible in some semiconductors; in others, avalanche breakdown occurs first, but when it doesn't, current flattens out, or even goes negative (as is the case for GaAs (Gunn diodes), something about varying saturation velocity in different Brillouin zones, i.e. the electrons changing directions as they travel through the crystal).
Tim
And don't ever blow it or open it - a dead cat might or might not escape.
just read the op link wow that made me laugh thnks stupidity at its best directional quantum fuses loll
gonna listen interstellar movie again loll :-DD
Yes, it's for quantum customers--ones are are simultaneously rich and dumb.
For a quantum fuse to be subject to the Schrödinger's Cat paradox, it must be inside an opaque (e.g., ceramic) tube so that the observer throws away information to which he is physically entitled.
With a glass tube, the fuse can be inspected visually without disturbing its state, just like the poor cat imprisoned in a glass cage rather than an opaque Bakelite cage. Room illumination through the glass cage does not affect the quantum state of the radioactive nuclide that triggers the poison.
Ted has a Tesla coil... (go to 5:40)
https://www.youtube.com/watch?v=9yzjA9ZYYNk&t=340s (https://www.youtube.com/watch?v=9yzjA9ZYYNk&t=340s)
Blimey!
I thought these were something being flogged by a one-man band capturing the odd credulous sweepings off the floor to make a few bob, but it's enough to sustain an actual company with significant overheads. And employees, which prompts: surely they must realise it's bullshit and they just scamming people - it ain't just one bloke without morals but an entire company of them.
Next thing you know, they’ll be offering non-directional diodes to unrectify the noisy DC.
After reading through that thread, I came to the same conclusion as poster Phildick: "What you need to consider is how the power supply in the amp works here. The incoming AC is converted to lower voltage DC and stored in large capacitors. On switch on the caps are charged up to capacity and kept topped up. It is the electric in the caps that drive the amp not the mains cable or any fuses on the AC side. So, if taking the fuse out of circuit make a difference the amp must be faulty or badly designed."
I have no idea about the "venerable Audiolab 8000A" but if it's an audiophile product, one must assume that it has a shitty power supply.
I'd thought it would be interesting to see if that "Positive Feedback" certificate for their Orange fuse is real:
(https://www.synergisticresearch.com/wp-content/uploads/2019/12/PF-2019-Brutus_Orange_Fuse.jpg)
https://positive-feedback.com/masthead/ (https://positive-feedback.com/masthead/)
(https://i.imgur.com/atazJ5l.jpg)
Hopefully they'll reply back next week.
I've seen that a lot, people assume that if the plug fits it will work. A lot of audio equipment in particular gets damaged because for reasons I don't really understand most audio gear uses center negative while most other equipment is center positive.
I always rationalised this as the outer ‘shield’ grounded (-), but never took it for granted!
When I see this audiophoolery I should be shocked and apalled….. but I am not. We live in a World where some people think that Planet Earth is flat :palm:
A fool and their money are easily parted ;D
The people who make this ludicrous Audiophool kit are probably delusional as well so may actually think they are modern Einstein’s where Hi Fidelity Audio is concerned. People can make and buy what they want with their own money though, so these companies continue to exist with little or no official interest in their ludicrous claims.
Has anyone asked an Audiophool how they cope with the fact that the original recording systems that produce the media they play had none of this ‘special’ kit used in them ? Or do they buy ‘special’ recordings on ‘special’ media from ‘special’ trusted sources ?
I don't see a problem there. The original may be magically perfect, or could be atrociously bad, but that's not relevant (and is unfixable anyway). What they are concerned with, presumably, is that stuff they can control doesn't make it worse.
I got the email back very quick about that certificate and that was genuine and issued last December.
Just reread this:
Say it was directional like with diodes, how is that even possible for the fuse (one component) to be inserted in both directions at the same time like that as what I think they are suggesting?
Speaking of orange fuses I remember these:
https://highend-electronics.com/products/audio-magic-premiere-beeswax-super-fuse?variant=1203927563 (https://highend-electronics.com/products/audio-magic-premiere-beeswax-super-fuse?variant=1203927563)
(https://i.imgur.com/MxfBcP7.jpg)
I question in relation to "electron flow" what effect is that tiny bit of honey around whatever material that is going to do for the sound and what if you insert them in the wrong way?
Like that tiny drip of honey Beeswax on the ouside is going to do anything.
Just found a discussion about these orange fuses on AudioGoon:
https://forum.audiogon.com/discussions/new-sr-orange-fuse (https://forum.audiogon.com/discussions/new-sr-orange-fuse)
AudioGoon jaybe695 posts
10-09-2019 12:43pm
I find SR fuses to blow much more easily than a normal fuse with the same rating. After this happening a few times with the Blues I took the advise of Alfred at High End Electronics and bought a slightly higher rating fuse but it too eventually blew. Two pieces of highly regarded equipment this happened with that otherwise have no problems.
No problems with the fuses blowing? Well that says something.
So an orange one of these blows up more than a normal use, that can't be right can it, that it should blow like that to be replaced more often and even with a higher rating but the normal fuses were blowing less then there must be something obviously not right with the equipment.
The two pieces of equipment are so "highly regarded" that it's perfectly fine for them to develop a fault and blow up fuses, that makes them okay and safe because they're "high regraded".
The complete schematic is posted here, you can analyse it for yourself. It's about the most basic linear PSU possible, very typical for the time and probably wouldn't pass EMC if it were tested to today's standards.
https://www.avforums.com/threads/audiophile-fuses.2348393/page-6 (https://www.avforums.com/threads/audiophile-fuses.2348393/page-6)
Well if fuses are directional, then so must be resistors. So are all the resistors in the stereo amp or other box all inserted the right way? Or all the wiring?
What they come up with is something to sell that can be replaced by the customer. Are they selling directional resistors to replace all the ones in your system? Nope, because most people wouldn't take apart the box and do that kind of work. If they did, they would sell directional replacement resistors. We're trying to analyze the irrational, rationally. It won't ever reveal anything more than people are ... irrational and there are plenty of scammers waiting to take their money.
"There's a sucker born every minute"
P.T. Barnum
Dunkemhigh,
Regarding the source material….. I agree but what I was meaning was…. With some audiophiles so focussed on maximum audio fidelity, how do they mentally cope with the idea that the source material is so ‘compromised’ at the recording stage. When people are spending many thousands of Dollars on cables etc, I would expect their minds to implode when they realised how ‘appallingly poor’ the equipment was that actually captured the original audio signal ;D In an Audiophoolery environment that hates anything less than ‘acoustic perfection’ how can a source of less than perfection be tolerated ? It may well be beyond the Audiophile to correct the terrible fidelity issues that they might perceive being introduced by such ‘imperfect’ recording studios but surely that would annoy their amazing ‘sonically calibrated and perfect’ ear drums that they moisturise daily with concentrated Angels tears ;D
The perfectionist can have a very troubled mind in an imperfect World !
And let us not forget the old saying… garbage in - garbage out ;D
Oh you could so mess with an audiophiles head if you really wanted to :-+
To be clear…. We are discussing Audiophoolery and Audiophools here and NOT Hi-Fidelity enthusiasts for whom I have nothing but respect. High Fidelity reproduction of a source material, no matter what the original quality, is totally understandable. Worrying about the electron flow direction in a power supply fuse is a million miles away from the thought processes of Hi-Fidelity enthusiasts and designers that I have met….. they live in the real world and genuinely care about correct amplifier design, component noise figures, crosstalk, harmonic distortion and other specifications that are based upon good science and fact rather than Snake Oil salesman Audiophoolery theories and products.
If a Hi-Fidelity designer asked me to pay £10K for his amplifier because he has spent 15 years of his life perfecting it and hand picked components, based on real testing in order to create the best possible bandwidth, noise floor, distortion, channel balance and separation…. All hand built on very high quality PCB’s with only first grade components of the highest true (not Audiophool) specifications, I might consider his product worthy of such an asking price.
A life’s work deserves just rewards. I still would not spend that sort of money on the amplifier though as I know my poor ‘acoustically abused’ ears are over 50 years old and imperfect ! ;D
They wouldn't take it apart to desolder a resistor and solder a new one in but... perhaps they might take it apart to attach the stick-on uni-directional e-field tube wrapper. Easy for the owner, and since the tube has to be split to get it on, you can always say they didn't join up the edges correctly if they don't notice any difference. You could make it out of something quite brittle too.
Now your getting it. You can make money on that! :-DD
