Author Topic: 7 segment Nixie tube clock.  (Read 1076 times)
Offline TinkeringTomasTopic starter
« on: March 18, 2023, 02:52:15 pm »
All I could think was "no. just.... no!" when I found this in a local store. Karlsson actually makes quite nice (analogue) clocks but they should best stick to that, I guess.
(As you would expect, the LEDs were multiplexed so that looks a bit weird on the picture)
Offline shapirus
  • Country: ua
Re: 7 segment Nixie tube clock.
« Reply #1 on: March 18, 2023, 02:59:24 pm »
Online TimFox
« Reply #2 on: March 18, 2023, 04:17:25 pm »
The good NixieTM tubes had a cathode for each numeral, carefully stacked to minimize interference with each other, in a neon-filled glass envelope.
The trademark belongs to Burroughs, who later merged with Sperry to form Unisys.
Offline SiliconWizard
« Reply #3 on: March 19, 2023, 03:51:07 am »
Well, I don't really like the looks of it either with those LED displays, but to each their own.
Certainly it's cheaper to make than using Nixie tubes, and probably more durable as well.
Offline retiredfeline
« Reply #4 on: March 19, 2023, 04:28:51 am »
Ah these must be the LED tubes they talk about in AliExpress ads.  :-DD
Offline shapirus
  • Country: ua
« Reply #5 on: March 19, 2023, 08:20:55 am »
Btw, even if these LEDs were real tubes, the clock would still look like crap.
This is now a matter of personal taste, but really this "just stick a few tubes in a block of wood" design is akin to those audiophile amplifiers with tubes exposed for the sole purpose of demonstration that it is a tube amp. Can't get more lame than this.
Offline Gyro
« Reply #6 on: March 19, 2023, 10:51:51 am »
....akin to those audiophile amplifiers with tubes exposed for the sole purpose of demonstration that it is a tube amp.
To be fair, it isn't the sole purpose. Tubes dissipate power by thermal radiation, it works better to radiate that to the outside environment rather than heating the internals of the amp. It would be different it they were lower temperature devices that were mainly cooled by convection. I gennerally agree with the 'stuck in a block of wood bit though.
Best Regards, Chris
"Victor Meldrew, the Crimson Avenger!"
