And that's the problem: fuckwits. Wall to wall fuckwits. Need to lock their hands away somewhere separate from the rest of them.
The problem with that solution is that to lock their hands up somewhere separate from them you first need the hands to be separated. Leave them alone for an hour in a workshop with some stock, a Bandsaw, a Lathe, a Milling machine and a copy of "A Makers Guide to Metalwork" ought to get the job done efficiently and with the minimum of human involvement.
I'm
so with BD139 on the walking personifications of the Dunning–Kruger effect that perpetrate this crap. The most dangerous thing about these people, and the cult of personality that goes with it, is that when challenged by people who actually know what they are talking about they don't react the way any intelligent person would and reevaluate their level of understanding, they just go into denial.
For anyone who hasn't yet realised what a shitshow this was, here's one resistor from what was, let us remember, a safety critical system.
There is no way that is acceptable in a safety critical system, with no redundancy, that flies 95 kg around in the air and that was capable of getting high enough to return to earth at terminal velocity with a kinetic energy of at
least 100 kJ.
There are more pictures in the report of egregiously bad construction. All the electronics in the UAV were held in place with bloody nylon cable ties just looped about the frame members - not a screw, shakeproof washer or safety wire anywhere in sight.
The CAA don't come out of this covered in glory either. From the report:
The CAA’s UAS Unit consists of two sections, the Policy Team and the Sector Team. The Sector Team has responsibility for the oversight and management of OSC’s. At the time of the application, the CAA’s UAS Sector Team comprised of a Section Lead, one UAS Technical Inspector and two UAS Technical Surveyors. There were plans to recruit a further two Inspectors and two Surveyors. The Section Lead, who was the signatory on the exemption, had joined the CAA in May 2018 from an emergency services organisation where they had introduced UAS operations; he has since left the CAA. Other members of the UAS Sector Team joined the CAA from university and initially worked in data entry roles within the CAA’s Shared Services Centre. The Technical Inspector took up the role in January 2019 after working as a UAS Technical Surveyor for approximately one year. One UAS Technical Surveyor, was still undergoing initial training and development.
Translation: The section leader had organised drones for the police or fire brigade and probably had no prior regulatory experience, or aerospace experience. Most, possibly all, of their staff all came from university straight into the CAA to work as data entry clerks and they decided it would be a good idea to put them to work as "Technical Inspectors" or "Surveyors". You can guess what's happened by what is omitted, all mentions of prior qualifications or experience. For all we know they were English or Philosophy graduates and the fact that they don't call out degrees in relevant areas is a strong indicatior to me that I'm on the right path.
Edit: Re-reading this I'm reminded of a phrase that commonly crops up in UK criminal that goes something like this: "A personal will be guilty of an offence
if they knew or should have known that
<something they omitted to do was criminally negligent>". You'll find that as far back as Victorian laws. There's a duty on people to recognise when they are out of their depth so that if they didn't know enough to know whether something was right or wrong they should find someone who does know what is right and what is wrong. That bloody resistor screams at me that somebody "
should have known" that it's wrong or should have had the sense to "ask a grown up".
