Author Topic: Another Aliexpress capacitor-fest  (Read 9492 times)
Offline 5U4GBTopic starter
« on: March 19, 2024, 12:16:34 pm »
Another piece of capacitor artwork from Aliexpress:
It looks like a sort of Greek-temple inspired artwork, a colonnade of supercaps surrounding Doric(?) rows of electrolytics and then an inner sanctum (cella) of SMD caps, because if one is good and ten are better then seventy must be even betterer.
You can complement it with this super DAC:
Offline Haenk
Re: Another Aliexpress capacitor-fest
« Reply #1 on: March 19, 2024, 01:34:37 pm »
I really wonder if the discrete DAC is any good. For 1k (plain PCB) it really has to be exceptional, which I doubt. Will it beat the 1792s in my Denon player? Or the 1704s in my Denon amplifier?
« Reply #2 on: March 20, 2024, 04:55:52 am »
I was curious too and did a quick search for "ladder dac", and have discovered that they're a thing in the audio woo-woo world, so this isn't just some random electronic art curio.  Of course the results are, uh, mixed.
Still, a great way to turn a few dollars in SMD resistors into $1,000+ of audio gear.
The following users thanked this post: Haenk
Offline Haenk
« Reply #3 on: March 20, 2024, 11:25:46 am »
It seems, tested discrete DAC is not bad, but not better than an average integrated DAC, while good DACs will only cost a third. So probably only a waste of money, they look impressive though.
Offline SiliconWizard
« Reply #4 on: March 20, 2024, 08:41:07 pm »
It's IMO a complete waste of money compared to a good, modern sigma-delta DAC and I doubt it comes close in terms of THD.
But hey yes, that looks cool. Whatever floats one's boat really.
The following users thanked this post: wraper, 5U4GB
Offline tszaboo
« Reply #5 on: March 20, 2024, 10:38:57 pm »
Hopefully nobody tells them about the thermometer coded DACs or string DACs because sooner or later we will see DACs with 2^24 resistor in them.
« Last Edit: March 20, 2024, 10:41:18 pm by tszaboo »
« Reply #6 on: March 21, 2024, 09:20:49 am »
Nah, what you need is a whiffletree DAC.  Just feel the audio purity created through the use of a purely mechanical DAC!
Offline Kim Christensen
« Reply #7 on: April 02, 2024, 11:29:29 pm »
I remember long ago driving a R2R DAC from a 27C256 UVEPROM as a crude voice playback method. Never knew it was sooo fancy!  ;D
Love how they called it a "Professional designed o-ring transformer" in that thing.  ::)
Offline themadhippy
« Reply #8 on: April 03, 2024, 12:51:05 am »
string DACs
use wet string if its an AES signal
« Reply #9 on: April 03, 2024, 01:04:12 am »
Just remember to never run your o-ring transformers at temperatures below 53 °F (12 °C), lest it cause o-ring erosion and they let all the electrons out.
