Anyone got links to the patents?
I only found this:
No product, no patent filed...? Chinese orginated from, never bother with filing patent? Want to keep secret and never filed the patent?
The last one would be dumb..I would guess anyone could reverse engineer the design..
Not quite sure I understand the thermal issue here. Surely only the nearest coil will be on, so what's the difference with a normal Qi charger coil?
Maybe some periodic sampling overhead, but not much?
Multiple devices placed at random positions on the same mat was the goal.
Yeah, but how does that create thermal issue?
It searched for devices and only turns on that coil fully when a device is over it. What's the difference between say two normal Qi coils side by side in the same case and this design?
Did I her 30 plus coils? powered from looked like a USB connector?? 5v and at best 2A? I wonder if it is not the coils themselves, rather the buck converters to power up those many coils?
Maybe Apple just did not get managing only the coils around the unit to power up only. Even Apple has done some stuff that engineering just missed a solution right in front of their eyes...
