As I recall it was a premium mainstream magazine, What HiFi maybe. I expect better levels of knowledge from that kind of publication.
Supercaps (1-2.2F) were starting to appear by that time, mostly from my recollection aimed at the car audio market.
Using lead acids isn't a horrible idea, it's a good one, if somewhat high maintenance. At the time gel types were rare and expensive, and given the low probability of the DC rails in the amp being at the correct float voltage for a string of 12V batteries, that means using individual cells to try and get close.
The local authority I work for still has quite a few properties with wet cell central battery units for the emergency lighting systems, and those 50-odd long strings of Plante cells are a bastard to keep topped up.
Not to mention the fact that improper charge voltage/current can have serious consequences... hasn't happened to me, but a colleague topped half a string up, went back the next day to finish (he'd run out of de-ionised water), and found the inside of the door to the battery room studded with shards of battery casing. Fun times!
