Products => Dodgy Technology => Topic started by: petrinm on May 18, 2020, 08:16:33 pm
Title: CC-100 Power Optimizer and Cybersecurity Enhancement
Post by: petrinm on May 18, 2020, 08:16:33 pm
Power Optimizer and Cybersecurity Enhancement!
That sounds awesome!  8)
So how do you like this snake oil(?) product for electronics engineers?
CC-100 (there are many variants. USB-plugs, OEM modules, silicon IPs, etc.) is basically an active(?) (super)capacitor IC's which claims to replace need for decoupling capacitors and at the same time decrease your device's power usage, suppress EMI and protect you against cyber hackers when soldered parallel in your processor's VCC. Some of their (randomly selected) claims in are:
Technical description from the CC-100 IP's datasheet.
The CC-100 IP is a decoupling capacitor with a Cybersecurity Enhancement and an
Energy Harvesting twist. The IP not only does a better job of on chip supply line filtering,
showing up to a 2X improvement in effective capacitance per unit area with respect to
typical on-chip MOS decoupling capacitors, with an added 25% reduction in capacitor
effective series inductance (ESL). The IP feeds back a portion (nominally 20%) of the
bypass current flowing through on chip decoupling capacitors onto the chip power grid,
thus reducing overall chip dynamic power draw. These effects substantially reduce RF
Emissions from chip power grids making systems less vulnerable to cyber hacking and
more secure. The IP draws no current for operation, thus maximizing block efficiency.
Some links:
What do you think?
Where does the line go between a real product and snake-oil? Is this just ultra fancy "power factor corrector"?
PS. They are also offering possibility to loan a device for testing. Any volunteers?
Title: Re: CC-100 Power Optimizer and Cybersecurity Enhancement
Post by: daqq on May 20, 2020, 07:00:33 am
So, it's a low-ESR capacitor that you plug into your USB? Or am I missing something?
Post by: Gyro on June 15, 2021, 09:29:45 am
Wouldn't they need to put a resistor in series with it to prevent it from tripping the USB port over-current protection when you plug it in?  ;D
Post by: Stuart Coyle on June 16, 2021, 04:28:22 am
Wow! A capacitor that "draws no operational DC power"... :palm:
Post by: meadlobon on August 03, 2021, 11:54:01 am
This isn't how you try to suppress EMI (electromagnetic interference).
This method is used to increase the capacitance of the capacitor. It reduces the frequency at which you can be cyber-attacked. So you can use this method by plugging the capacitor into the computer's USB port, not into the computer power supply.
Then, if you want to use it when you connect it to the power supply, you need to use a filter. And in general, you should never forget the human factor because it can work wonders. Nonsense miracles, of course, always make sure you have enough knowledge of security awareness (https://websec.nl/en/security-awareness/) to be up to date with modern hacking schemes.
Post by: Simon on August 03, 2021, 12:15:36 pm
Of course we won't count the ESR of the USB socket to the um, processor was it? like the one on sub 5V so not on the same power rail?
Post by: Marco on August 21, 2021, 08:07:31 pm
Maybe it has an integrated DC-DC converter to create a higher voltage internally and then keeps the bus voltage constant with some kind of capacitor multiplier?
With miniaturization it does seem it would start to make sense to start making decoupling capacitors active components I guess, you should be able to do better than a plain capacitor to keep bus voltage constant.
Post by: Haenk on August 26, 2021, 11:12:37 am
I'm very tempted to buy one, for scientific purposes 8)
