Says someone in a 110V country! Try those lax approaches on 240V and you get quite the shock, literally.
I have spent time in a 240V country and did some electrical tinkering while I was there. I don't think using something that is maybe not the most well designed device is necessarily a "lax approach", I know better than to plug it in with live prongs sticking out, I wouldn't feel unsafe using it. 120V can be lethal too.
Did you try floating ground connection on devices with safety grounds? That was what you were talking about in the quote (that you mysteriously detached) and is the very "lax" approach that seems to be routine in 110V countries. 240V stray voltages are worrying enough, hence we take the protective earthing seriously.
You don't hear about people dropping dead all the time here. Grounding is a good idea that adds additional safety in the case of a fault condition but properly working equipment will work fine without a ground. I just don't see it as a big issue..
Plenty of equipment is right up against the maximum permissible ground return current, let that 3.5mA rip and its very unpleasant. Any faulty equipment however... exposure to 110V is roughly 10x safer than 240V depending on which reference you go for. Even a 30mA RCD isn't enough to ensure safety with 240V installs as they generally don't disconnect within 30ms, hence the push for faster and lower current RCDs (and needing more of them to distribute the intentional ground return currents).
