Author Topic: Dangerous pseudo science  (Read 5364 times)
Offline BobsonTopic starter
  • Country: ru
« on: March 04, 2021, 06:18:01 am »
Barefoot walking under power line will neutralize EMF and other BS.
Dave, you should pay more attention to the projects which are dangerous to health. If you loose money you can gain experience. If you loose life, you gain nothing.
Offline JohnnyMalaria
    • Enlighten Scientific LLC
Re: Dangerous pseudo science
« Reply #1 on: March 04, 2021, 01:41:50 pm »
But eventually give you Lyme disease.
Offline Haenk
« Reply #2 on: March 05, 2021, 12:48:29 pm »
I assume he just needs to trust the sensitivity of his tinfoil hat, no need for that multimeter rubbish.
If his head starts to tingle, he is too close to a 150kV power line 8)
Offline madires
  • A qualified hobbyist ;)
« Reply #3 on: March 05, 2021, 01:54:15 pm »
Long time ago I built the Elektor Teslameter for checking CRT monitors and other EMF sources. The TCO standard back then had a maximum limit of 250nT for CRT monitors, IIRC.
Offline SiliconWizard
« Reply #4 on: March 05, 2021, 05:17:36 pm »
I have watched the video very quickly, fast forwarding a lot, just to get a quick idea of what the guy was on about.
As far as I got it, he seems to be discovering one of the effects of "electrical earthing" and measuring potential differences without understanding what they mean.
So is he suggesting to use earth mats inside his house? That could actually be dangerous indeed if the installation is not properly made and checked by a professional, especially if he's going to walk barefoot on this.
As to the potential benefits of having our body electrically connected to earth, it's apparently one of those new-agy trends that I didn't know even existed until now:
https://www.earthing.com/pages/what-is-earthing
The following users thanked this post: MrMobodies
Offline madires
« Reply #5 on: March 05, 2021, 05:35:02 pm »
Albert Einstein: "Two things are infinite: the universe and human stupidity; and I'm not sure about the universe."
The following users thanked this post: SeanB, MrMobodies
Offline CJay
« Reply #6 on: March 05, 2021, 09:58:24 pm »
If it's only tingling I'd suggest he's perhaps not close enough.
Offline fubgumfaw
« Reply #7 on: March 06, 2021, 11:50:22 pm »
I see a lot of condescending attitudes and dismissing what he says but no explanations.
He does make several good points here.
1. He can measure voltage across his body with a cheap DMM.
2. Bare foot to the ground and that voltage disappears.
3. He shows clear evidence that the power lines are inducing a voltage across his body. I've done this myself.
4. There has been much dipping and dodging from the power companies and cell carriers about EMF and the effects it has on the body.
5. Money does decide what is held as truth and what is pseudo science. People get off for crimes all the time because they have money!
I'm not saying grounding the body has a positive effect or not. I honestly don't know despite reading about this some in the past.
What you can't deny is that he demonstrated the voltage across his body induced onto it from the power lines or the AC in his house.
THAT HAPPENED! What's the effect on the human body? Do you really know?
« Last Edit: March 07, 2021, 12:00:33 am by fubgumfaw »
The following users thanked this post: bsfeechannel
Offline penfold
« Reply #8 on: March 07, 2021, 12:02:16 am »
I see a lot of condescending attitudes but no explanations. He does make several good points here.
3. This is clear evidence that the power lines are inducing a voltage across hid body.
Surely the conclusion should be that the voltage is across his shoes...
Offline MrMobodies
« Reply #9 on: March 07, 2021, 12:21:55 am »
02/05/20 - 07/03/21  Up: 501 down: 8
claudio kessler, 7 months ago
great video, just what I was looking for.
Nonattachment Lee, 5 months ago
Thanks for all kinds of testing. Great video
Noe D, 2 months ago
Thanks so much.  Very informative!
Phillip Jacowski, 8 months ago
awesome video
Kobi Chu, 5 months ago
And what is the name of this cable? And where can I buy online? Appreciate for your help!
Joe Milford, 2 months ago
Thank you for your research. God Bless You.
SpaceWalkTraveller, 2 months ago
Thanks for the video.
Marty Morgan 5 months ago
Explained to the point that I finally understand it! Thank you for the lesson. Great video.
So many who believe it.
I mean't Silicon Wizards post in relation to the audience's understanding of what he was doing.
My mistake I quoted and thanked the wrong post by mistake.
« Last Edit: March 07, 2021, 07:28:44 pm by MrMobodies »
Offline fubgumfaw
« Reply #10 on: March 07, 2021, 03:35:56 am »
Noe D, 2 months ago
awesome video
OK...challenge laid...HOW then do you explain what his DMM so clearly displayed? I've done this with a DMM myself and I already know that if you stand near power lines that you can measure a voltage on yourself and that if you ground yourself you can't. This is not disputable or a "maybe could be". It's fact. Go do it yourself. He's not presenting BS when he measures a voltage on himself. This IS a real thing!
Offline fubgumfaw
« Reply #11 on: March 07, 2021, 03:40:15 am »
OK...maybe...sure...HOW exactly?
Also, you can get away for AC power without too much trouble. The middle of grassy field is good enough. And in the middle of that field you can do this same test again and the voltage you will measure inside rubber shoes will be significantly reduced. There is something here and you do get a voltage induced across your body from near proximity to AC power lines or wires in the walls.
I have to laugh at the title for this thread. How is grounding yourself dangerous? So what it doesn't work to improve your health. Was it harmful in any way? "Dangerous" is the wrong word to use. How about "pointless pseudo science"?
« Last Edit: March 07, 2021, 04:13:51 am by fubgumfaw »
Offline penfold
« Reply #12 on: March 07, 2021, 04:06:49 am »
The electric field will still be present, but the minuscule current that first flowed through the DMM to produce such voltage is now being shorted to ground via his feet
Is "EMF" worse than current to him?
Offline fubgumfaw
« Reply #13 on: March 07, 2021, 04:24:00 am »
I agree the current is quite low. Maybe a few milliamps? How harmful can that be?
I also have to ask why cancer rates are higher now than ever before? Is cancer related to EMF? What about mental illnesses which are also higher now than ever before. We keep getting told by the power companies and cell carriers that their EMF is harmless. This is in their best interests to NOT tell you that there is possible harm in EMF. Also, anyone that presents a dissenting point of view is dismissed. I hardly call this situation a good way to present facts or study results! This isn't proof of EMF causing cancer or mental illness, just that I'm skeptical that there is no link. We are bathed in EMF all the time. Who doesn't have wifi or a cell phone or have AC power now days? I think there is something to the upward trend in cancer and mental illness and that it is possibly EMF related. Will grounding yourself help? No idea! I'd like to see studies on this!
Offline penfold
« Reply #14 on: March 07, 2021, 05:14:54 am »
Probably microamps if not lower, but the electric field is there, all he's done is render the meter incapable of measuring it (not that it was a particularly suitable instrument to begin with)
The proliferation of electricity and wireless technology also coincided with advances in medical diagnostics and characterisation of mental disorders/illnesses so naturally there are more diagnosed cases now. But equally, society has changed over the same time frame and there are significantly more known and studied causes of cancer and mental illnesses which are not "EMF" related. I'm still not disputing the potential for its effects, but it would be improper to draw a conclusion where "EMF" is a significant cause of cancer and mental illnesses when the current scientific understanding of those conditions does not and there is such a huge amount of "sociological noise" in people's habits.
It is also very much not in the interests of power companies and cell operators not to give their customers cancer, unless they're expecting them to continue paying their phone bill posthumously.
Offline fubgumfaw
« Reply #15 on: March 07, 2021, 07:51:06 am »
I'm not concluding that all the EMF we are bathed in is good or bad, just that I'd like to see independent studies that are not based in the agendas of the power and cell companies. As far as I know, they are the only ones doing them and I find that just a little suspicious.
You are right, all that electrical advancement has come with many good things. I'm an avid EV builder. Without those advancements, I would still be riding around on gas engines! I've increased my EMF exposure significantly as a result too. Also, with all that great technology, we've been able to diagnose things much more readily. So maybe, it's not that cancer and mental illness have increased, but rather our ability to detect them has increased? Sure! That's quite possibly it...
Offline CJay
« Reply #16 on: March 07, 2021, 08:28:51 am »
You're on the edge of or possibly already on the downward slope towards paranoia and conspiracy theory, if you google for studies you'll find many independent, peer reviewed, accredited studies performed by people who have no connection to power and cell companies.
The problem with doing that is you'll find any number of lunatics screeching loudly about how their auntie's friend's dog fell off the couch when the WiFi router rebooted or some such anecdotal bollocks so therefore all WiFi is eeebil and power lines must cause cancer because people who have electricity in their homes get cancer.
The following users thanked this post: janoc, Andy Watson, Cyberdragon, newbrain
« Reply #17 on: March 07, 2021, 10:31:12 am »
Quick reason cancer rates are rising is a combination. Plastics and lead exposure from decades of TE lead in fuel, and improving world health standards, so that people now live much longer lives, so that the cancers that occur now actually do get to kill you, instead of you dying much younger from some other disease that is now curable, or controllable with modern health advances (washing hands and aseptic handling of food being probably the biggest step forward), now leads to people living long enough to die from slow growing cancers.
Well known that most prostrate cancers in men over 80 are not treated, simply because in the vast majority of cases something else will kill you, long before the cancer gets to the point where it will, unless you get the rare fast growing types, which are treated, mostly by using pins made from gold plated Polonium inserted in the area, to destroy all cells there that are rapidly dividing.
Offline fubgumfaw
« Reply #18 on: March 07, 2021, 11:29:07 am »
I have to say that I'm not coming to the same conclusion as you have. You are acting as if conspiracies do not exist and yet we all know that they do happen.
There is a good probability that you are male, since this is a tech forum and from personal experience, about 80% of tech people for whatever reason are male. Is that a paranoid conspiracy or am I just stating a real world observation?
So then, here's a conspiracy for you! I conspire to have sex with the next hot woman I find myself in bed with! EEEEEK...OH the Paranoia! Hahaha!
I have to wonder when healthy skepticism became a tainted thing. Slippery slope into paranoia and conspiracy theories? Really? How about skepticism?
« Last Edit: March 07, 2021, 11:32:23 am by fubgumfaw »
Offline madires
« Reply #19 on: March 07, 2021, 12:43:44 pm »
If you want to know read studies about the impact of power line EMF (also EF and MF) on humans, and stop fearmongering.
« Last Edit: March 07, 2021, 12:49:39 pm by madires »
Offline CJay
« Reply #20 on: March 07, 2021, 12:55:14 pm »
Not on the edge, over the edge.
Offline bsfeechannel
« Reply #21 on: March 07, 2021, 04:09:53 pm »
You're right about points 1, 2 and 3. You are also entitled to be skeptical, as per points 4 and 5. Until the 1950s, smoking wasn't considered dangerous.
However, the guy in the video doesn't seem to know what he's talking about. We use grounding at electronics workbenches, but that's to protect sensitive components against damaging electrostatic discharge, or even electrical induction as you saw in the video. In fact this even poses a risk to the operators. If they touch a live chassis for some reason they'll close the circuit between live and ground and be zapped. That's why in many cases a 1MĪ© resistor is put in series with the wrist strap cord installation.
In construction sites where you frequently find water and power tools together it is the exact opposite. Power tools are not grounded. They're double-insulated and the workers wear insulating boots. Those measures are intended to protect people from hazardous electrical shocks. No one cares about EMF there.
Absent from his video is the use of a Faraday cage, which is effective to protect you from the meanest electric fields out there, as can be demonstrated by Dr. Megavolt.
« Last Edit: March 07, 2021, 04:21:32 pm by bsfeechannel »
Offline MrMobodies
« Reply #22 on: March 07, 2021, 07:13:20 pm »
It was not mean't for a challenge I think I made a mistake,  I quoted and thanked the wrong post when it suppose to be the one up which is Silicon Wizard.
It wasn't "stupidity" that I was referring in that post but it was the understanding what he was doing in the Silicon Wizard's post above and me assuming that audience didn't understand too which some may have done. It is my fault, very embarassing I didn't double check my post.
Sorry about that.
I was told about how it can also excite flourascent tubes.
« Last Edit: March 07, 2021, 07:29:45 pm by MrMobodies »
Offline Nominal Animal
« Reply #23 on: March 08, 2021, 06:52:09 am »
Ordinary atmospheric voltage potential is about 100 V/m near the surface, but it varies quite a bit; near trees and plants it can be several kilovolts per meter.  The currents involved tend to be small, on the order of two picoamperes per square meter in free air.
So, we do know that biological systems on Earth deal with ("slowly") changing electric and magnetic fields.  We know that some birds use the magnetic fields for navigation, and it looks like some insects like bumblebees and arachnids use these electric fields to detect nearby plants.
The fact that the transmission lines use alternating currents at 50/60 Hz does affect the picture somewhat.  Simple measurements show that the effects are very localized to a narrow zone beneath the transmission line (width similar to the height ā€“ or ground-line distance).  Observations on plantlife along transmission lines hasn't shown any alarming cellular effects, nor does it seem to negatively affect transient insects.  (For example, pollinators do not seem to be adversely affected.)  This indicates that there does not seem to be any short term effects; that is, we haven't observed any negative short term effects.
Very strong magnetic fields, however, do have health concerns, but involve magnetic fields much stronger than those associated with electric power transmission lines.  This should not be a surprise, because natural magnetic fields are rather weak compared to natural electric fields.
Many people do not realize that all life on Earth is subjected to all kinds of conditions, including quite a bit of ionizing radiation, including gamma rays (both from space, and from natural radioactive decay).  Because biological systems evolve to fit the conditions, it is not at all certain that removing those actually improves health.  For example, there is quite a bit of evidence that because human immune systems have evolved to deal with parasites, the prevalence of allergies in Western countries is actually a result of lessened parasitic load especially in childhood.  Because of this, some of those who suffer from life-threatening allergies have sought help from acquiring intestinal parasites; a very controversial topic.  (We already know many illnesses that are relatively safe when had as a child, giving a lifelong immunity, but can be very dangerous as an adult.) This means that there definitely is some kind of "boundary" for each stressor beneath which exposure is "safe" and above "not safe", but that boundary varies and depends on other stressors, and thus far our only tool to characterise these is via statistics.
But.. how do you do statistics when the numbers involved are on the same order as people being crushed (injured or died) by tipping vending machines?  Or when you have a dozen or more variables affecting each other in a very nonlinear, almost chaotic, manner?
Me, I'm much more worried about the fact that current academic papers' quality is dropping, if we use the fraction of withdrawn or later proven incorrect as a measure of quality.  (It's not just a small fraction, but between 25% and 50% on many STEM fields, so is a serious concern.) On top of that, we have media whose best option to remain relevant is to rile people up, via scaremongering and simplification and misunderstandings and, well, clickbait.  And this means that anyone doing the kind of statistical analysis I am referring to as necessary to determine what constitutes "dangerous" ā€“ keeping in mind that because we are an intrinsic part of the biome surrounding us, any change, no matter how "obviously good" you might think it might be, is potentially dangerous; and "no change at all" possibly being even more dangerous (as we've observed that to lead to overspecialization, loss of adaptability, leading to species loss when the environment changes) ā€“ anyone doing that kind of statistical analysis has serious financial and career incentives to well, skew the results to get more publicity.
The following users thanked this post: helius
Offline fubgumfaw
« Reply #24 on: March 08, 2021, 07:10:27 am »
No one...certainly NOT me as doing an fear mongering! You twist what I say into a phobia that doesn't exist!
