hi,
that's like the cases in France country-side, where dozen babies are born without arms, there are studies but non-concludent (i'm talking about government studies after those medical issues appeared in mass-media). people blamed pesticides, other people suggested radiation minerals.
anyway, on those subjects regarding cancer from aliments or radio products, all studies will be 'not concludent'
i'm not conspirationist, but a pattern forms here, it's called capitalism stupidity.
of course chemicals have side effects, radio too, some organisms are more susceptible then another.
can we officially talk about this. NO, we are bad seeds by just asking the questions. the state doesn't do his feedback role, it's compromised, conclusion for sincere scientist from top-labs are censored.
do you think, if you can buy 100 euros device to move your muscle without your neural network to give the impulses, that radio is absolutely non-invasive? my answer is categorically no.
i worked almost 5 years as radio support engineer, had 'radio cash bonus'. i don't have medical issues on this side, i guess my body is not that sensitive to this. others are, i had colleagues with headache when exposed longer than 2-3 hours near relays in vhf. but my oppinion, higher the freq, we approach wavelengths close to our internal ones.
even for lower ones, that's a reason fences are around big power transmitters in simply AM relays. people died by not shutting down the transmitter before entering the perimeter.
The fences are there to stop idiots climbing on masts,-----in MF radio broadcasting, the usual design is that the whole mast is insulated from earth, & is in fact, the antenna.
Because of this, the mast is "Hot" with RF, & at kW levels and above can give you life threatening burns
if you touch it!!The other, very possible danger with
any mast or tower, is that unauthorised climbers may well fall to their deaths.
The main MF site I worked at had a "Dual mast" where the same vertical radiator was fed with 55kW at 720kHz, & 10kW at 810kHz.
One of the more pleasant duties of being on shift there was, on a nice day, moseying down the footpath next to the two feeders to the "mast" hut, & once there, to read & record the line, dual coupling unit, & mast current readings.
To do so, you needed to open the hut door, enter, & stand inside for as long as it took to do the readings.
On emerging, we would stroll around to make sure there was no visible physical damage to what parts of the mast, etc we could see from ground level.
The fenced area enclosing the base of the mast is quite small, so if you stand just outside the fence, you are still only a couple of metres way from the mast, so any "woo-woo" magic "bities" can happily find their way through the quite ordinary mesh fencing, or over it!
In all my years in Broadcasting, I knew various people who died accidentally------3 were in aircraft crashes, 2 in falls from heights,
Nary a one from "just kicking the bucket" from getting too near a Radio mast!
Sorry, but your
"almost 5 years as radio support engineer", doesn't cut it on this forum, where the vast majority are people with a solid grip on technical subjects, as well as hands on experience.
Go & regale dumbos off the street with your spurious expertise!
