Is it covered by Medicare Part C (Advantgae) plans?
Joke: I'd imagine it'd include free AI to help preauthorize your claim.
But what if modern devices were trying to take that away from you?
What if the modem devices were in a metal cabinet.
I see they have this stupid animated "loader" thing that pretends that the page hasn't loaded when it has.
Ablock##.loading-wheel-wrapper
Page loads instantly now but the stupidity.
I remember Argus did something similar before when some content would load instantly and then this animated "preloading" element would appear and cover up the contents after they had loaded.
I wonder what is it:
Product Weight 1 lb. 15 oz.
Product Dimensions 3 (diameter) × 7 in.
Box Weight 2 lbs. 7 oz.
Box Dimensions 8 ⅜ x 3 ½ x 4 ⅝ in.
Shipping Weight 2 lbs. 12 oz.
Shipping Dimensions 6 x 5 x 10 in.
Product Lifetime 5 years
Product Warranty 1-year manufacturer defects warranty
Protection Area Horizontal: 8-ft. radius (16 x 16 ft.)
Protection Area Vertical: 6 ft. up, 6 ft. down
Protection From Wi-Fi, 4G, and 5G
Wooden Material Walnut - 100% real wood, natural cut
Metal Material Copper or nickel-plated copper
Interior Materials: Copper, gold, and silver wiring; glass; *proprietary* liquid
Is it some coil of wire or some foil wrapped over something.
PDF manualhttps://ultraluxhealth.com/wp-content/uploads/2022/12/Qi-Shield_Manual_v2.1.pdfTHANK YOU
Thank you for choosing the Qi-Shield! With this device, you can
protect yourself from EMF radiation both at home and on the go.
Even with its small size, the Qi-Shield allows you to go about your
daily routine without having to sacrifice powerful protection.
INNOVATIVE TECHNOLOGY
• Releases free electrons within a protected area to reduce EMF radiation.
• Depolarizes EMFs and reduces EMF exposure to make it biologically safe.
• Reduces the negative health effects caused by EMF radiation, including
oxidative stress.
• Tested to reduce exposure to 4G and 5G radiation.
• Scientifically shown to significantly reduce EMF exposure.
• Portable size for protection both at home and on the go.
• Designed to protect bedrooms, oces, small apartments, vehicles,
and your person when on the go.
USAGE INSTRUCTIONS
• Carefully remove the Qi-Shield from its packaging and protect it from
being dropped or knocked over.
• Keep the Qi-Shield device and packaging materials away from children.
• Place your Qi-Shield in your purse, backpack, car, or suitcase to protect you on
the go, or place in an area of your home where you spend most of your time.
• If you are using in your home, place your Qi-Shield a minimum of 10
inches away from all surrounding power and EMF-producing sources (i.e.
sockets, power cables, radios, and televisions).
• If you wish to experience grounding benefits, you can touch the Qi-Shield
on the copper ring for no more than 2 minutes once or twice a day.
• Please note that the Qi-Shield has a slightly smaller area of protection when mobile
ADVISORIES
Please read the following advisories before using your Qi-Shield.
Failure to observe these instructions will make your warranty void.
• Do not make any unauthorized changes or adjustments to the device.
• Do not disassemble the Qi-Shield device.
• Do not leave the Qi-Shield outside and unprotected for a long period of time.
• Avoid drastic changes in temperature or humidity, as these can cause
the wood to crack and the device to lose eectiveness.
• Keep the room temperature in the range of 26.6°F to 120°F (-3°C to 48.9°C).
When using the Qi-Shield on the go, it can be in an environment no warmer
than 140°F (60°C).
• Protect the Qi-Shield from rain, moisture, humidity, and heat, including
that from heaters and direct sunlight.
• Do not place any objects on top of the device.
• Do not place the Qi-Shield in the microwave.
OCCASIONAL MAINTENANCE
• Keep your Qi-Shield clean by wiping it down with a damp microfiber
cloth. Be sure to wipe any residue o with a dry cloth.
• Do not use cleaning solutions, chemicals, solvents, or caustic cleaners on
the Qi-Shield. This includes but is not limited to rubbing alcohol, acetone,
and petrol.
• Do not use a scouring cloth, sponge, or sharp objects when cleaning the
Qi-Shield.
• Avoid exposing the Qi-Shield to moisture for extended periods of time.
• Never clean the Qi-Shield under running or standing water.
• The Qi-Shield was designed to work at full eciency for 6 years.
Buzzword Bullshit: proprietary, technology, Waveguard technology, Qi-Shield, dna, depolarizing radiation, smart watches, INNOVATIVE TECHNOLOGY, powerful protection, free electrons, EMF radiation, oxidative stress.
Moment of truth in the smallest writing on that page:DISCLAIMER
Copyright© 2024 UltraLux Health, LLC - All Rights Reserved. The statements on this site have not been evaluated by the Food & Drug Administration. Our products are not intended to diagnose, treat, cure, or prevent any disease. UltraLux Health, LLC assumes no responsibility for the improper use of and self-diagnosis and/or treatment using these products. UltraLux Health, LLC products should not be used as a substitute for medically supervised therapy. If you suspect you suffer from clinical deficiencies, please consult a licensed and qualified medical doctor.
