Dear forum members,
I've decided to put my problem in writing since I've never encountered anything like this before. For many years I use Aliexpress as a reliable (now very questionable) source of SDRAM/FPGA/uC/Flash and many other expensive chips, which I can get for peanuts. I have saved tens of hundreds of $$ by sourcing the ICs for my prototypes from Aliexpress. And so far I've never had a single problem with the originality. I.e. in the worst case the chip was unsoldered before being packaged into the tape (this happed twice), but it was original.
Now, recently I've been looking for Spartan6 LX75 chip in fgg484 BGA package. And I bought two XC6SLX75 from the Aliexpress vendor. Seems like they have thousands in stock but nobody before me dared to buy these chips from them.
To cut the story short:
- Upon reception I've noticed little bit uneven shape of balls (assumed that this is process), and some very little color gradient on the PCB carrier of the chip on the bottom side.
Now, I've soldered both ICs and they have the very same result. JTAG is accessible, no short circuits, idle current is a bit high (Vcore Istandby=100mA), but device isn't recognizable by Xilinx since the ID doesn't match any known device to Xilinx. Also something pulls IO_L65P_INIT_B_2 pin low internally with the current of 50mA.
Since both chips behave closely (the Idle current differs by 30% between the two chips) I wonder whether this chip lot can be a fake?
I've contacted the vendor and they told me that this is the original lot.
Have you seen anything like that? What would you do in this case? I haven't lost a lot (40$ only), but mainly I'm cautious to buy this article again from Aliexpress....
