Author Topic: five volt four amp power supply, not.  (Read 2562 times)
Offline G7PSKTopic starter
  • It is hot until proved not.
« on: November 27, 2018, 04:17:52 pm »
I just purchased anNanoPi-NE04 with power supply as it requires rather more than usual. I checked the output voltage under load and of course it dropped to just over three volts at three amps.
So I took it apart and found an unusual electronic component, a ballast gravity ballast that is.
A nice chunk of sheared off steel they even went to the trouble of plating it, obviously top quality ballast.
Offline Wan Huang Luo
  • 顽谎骆 from the Shenzhen Market
Re: five volt four amp power supply, not.
« Reply #1 on: November 29, 2018, 06:09:03 pm »
 :o
Online SiliconWizard
« Reply #2 on: November 29, 2018, 06:20:15 pm »
A gravity ballast... ok. ::)
Offline kjr18
« Reply #3 on: November 30, 2018, 06:04:15 am »
Well, someone thought: The more power supply weights, the more power you can get from it. So I will take a regular 2A supply, stick inside some slab of metal to make it heavier, and here you go: 4A power supply. :-DD
I still have somewhere a power supply that is kind of too light to be a 12V 4A. Big enclosure but very light.
Offline Gyro
« Reply #4 on: November 30, 2018, 01:03:01 pm »
At least they maintained its RoHS status - they could have used Lead.  :)
Best Regards, Chris
« Reply #5 on: November 30, 2018, 06:40:26 pm »
That kinda reminds me of the fake cable grommets you can find on some cheap chinese products and that serve only as decorative deception. |O
