Author Topic: "Harness The Earth's Energy While You Sleep" (plug your bed into Mains wiring)?  (Read 2126 times)
Offline peteb2Topic starter
What a right ripper! This is the latest in WOO-WOO. For a bit over 100 quid you get a cotton bed sheet full of fine wires and a mains lead with molded 3 pin plug that connects to the Mains Earth !!!! Their blerb reads:    "Many are unaware that the Earth’s surface is covered by a blanket of electrons, which may act as one of nature’s most powerful antioxidants and anti-inflammatories. Every time we come into contact with the Earth’s surface, we are able to absorb these electrons through our skin through a process called grounding, or Earthing. Grounding during sleep provides the body with multiple hours of these free electrons, at a time where the body undergoes the most healing and regeneration"...   There's even a couple of Woo-Woo as hell videos.... and The latter features a dodgy DMM!  I'm impressed with the posh webpage though...https://rowlandearthing.co.uk/
Offline thm_w
  • Non-expert
I think saying "plug your bed into mains wiring" is making it sound much more dangerous than it is. Whether or not it provides any benefit I don't know, probably not.
There are a handful of small studies, but most of them are questionable:
https://www.liebertpub.com/doi/abs/10.1089/acm.2004.10.767
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC4378297/
https://journals.sagepub.com/doi/abs/10.2466/06.PR0.116k21w5
"Every time we come into contact with the Earth’s surface, we are able to absorb these electrons through our skin through a process called grounding"
At a capacitance for the whole earth of 711uF that's a lot of people sharing one terminal of a small capacitor to "absorb" electrons from. And if they do, will they reverse the polarity of the charge on the Earth? If that happens, will that make contact with the ground dangerous rather than beneficial? More worrying, there's Tantalum in the ground, and we all know how big a bang you get if you wire a Tantalum capacitor up in reverse bias!  :)
The following users thanked this post: peteb2
Online SiliconWizard
Connecting your sheets to a mains plug, what could go wrong? :-DD
Offline benbradley
This idea of being electrically grounded while you sleep has been around, I first heard of it years ago. Here's a "scientific" article on an experiment - it MUST be true because the study was "triple-blinded" !!!11!
https://www.frontiersin.org/articles/10.3389/fphys.2019.00035/full
Offline Gyro
I wonder if it works better if your mattress has coil springs rather than memory foam. Maybe you could hook into some Schumann resonance.  ;D
Best Regards, Chris
The following users thanked this post: MazeFrame
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
Don't wet the bed!  :-BROKE
Offline YurkshireLad
Offline Cyberdragon
*BZZZZZZAAAAAP*
Voltamort strikes again!
