Author Topic: Solar panels that make electricity from rain  (Read 3104 times)
Offline IanMacdonaldTopic starter
    • IWR Consultancy
« on: March 14, 2018, 08:09:44 pm »
https://www.theguardian.com/environment/2018/mar/13/rain-or-shine-new-solar-cell-captures-energy-from-raindrops
https://pubs.acs.org/stoken/presspac/presspac/full/10.1021/acsnano.8b00416
The current delivered by a raindrop is apparently 33nA.
I've always wondered why, in Scotland, they don't fit buckets to the tips of wind turbine blades. At least then they would generate power for most of the time.  :P
Offline jmelson
Re: Solar panels that make electricity from rain
« Reply #1 on: March 14, 2018, 08:41:35 pm »
It seems like that should be measured in Coulombs, not Amps.
Jon
The following users thanked this post: Kean
Online BrianHG
« Reply #2 on: March 14, 2018, 11:55:44 pm »
Since most panels are angled and have some elevation off the ground, what's wrong with placing gutters below all the solar cells, collecting the water flow with some simple plumbing and run a small hydro turbine?
Offline JohnMc
« Reply #3 on: March 15, 2018, 12:31:56 am »
Two things are wrong with that.
-  It would work therefor negating the need to research it to death.
-  Well not imposable it is much harder to run a successful* kickstarter on something that you can build yourself with a trip to the DIY store and a order from your preferred purveyor of chinesium like eBay, aliexpress or banggood.
*Successful=Lots of money for fast cars and fast women.
The following users thanked this post: TheWelly888, nugglix, BrianHG
    • IWR Consultancy
« Reply #4 on: March 15, 2018, 07:00:02 am »
Jon
No, it states that this is the current delivered. Coulombs would be charge delivered. Of course neither give any clue as to the actual power output. Which is probably miniscule.
Offline Delta
« Reply #5 on: March 15, 2018, 07:11:34 am »
Shurely* we should be talking about Joules (or other units of energy) per raindrop?
* cf Private Eye magazine.
Offline BradC
« Reply #6 on: March 15, 2018, 08:02:48 am »
We probably should, and don't call me Shirley.
