Author Topic: Israeli Electreon building "charging road" in Sweden  (Read 2182 times)
Offline nuclearcatTopic starter
  • Country: lb
Re: Israeli Electreon building "charging road" in Sweden
« Reply #1 on: April 08, 2021, 09:18:46 am »
I'm planning on becoming a billionaire and emigrating to Mars.
Let's see which happens first.
Offline MarkR42
« Reply #2 on: April 08, 2021, 09:27:42 am »
Hang on, isn't there already one near Arlanda airport? That uses slotcar-style pickups in the road? https://eroadarlanda.com/
It was installed in 2018 and has been almost silent since.
Isn't there another one further south near Malmo which uses overhead wires?
Sweden truly is the world leader in vehicle-charging roads.
Offline Daixiwen
  • Country: no
« Reply #3 on: April 09, 2021, 07:05:46 am »
In terms of logistics, the only inconvenience is that a portion of the asphalt needs to be removed and replaced. Other than that, the system can connect to existing power grids without the need for additional infrastructure or transformation stations.
Well until you have tens of thousands of cars on the road draining 70kW each of course  :-DD
Offline Nominal Animal
« Reply #4 on: April 09, 2021, 11:26:47 am »
As far as I can tell, these projects work perfectly for their intended purpose.
Which is to extract money from governments and municipalities wishing to spend other peoples money so their lead faces can claim they're making the world a better place.
Everybody wins, except the taxpayer and the environment; and nobody cares about the taxpayer or the environment, really.
The following users thanked this post: daqq, james_s, Jacon, RJSV, AVGresponding, srb1954
Offline Cyberdragon
« Reply #5 on: April 09, 2021, 04:22:14 pm »
Which is exactly why I decree that charging roads should be solar roads too, charge your car with crappy road sunlight. :-DD
*BZZZZZZAAAAAP*
Voltamort strikes again!
The following users thanked this post: Haenk
Offline SiliconWizard
« Reply #6 on: April 09, 2021, 06:28:59 pm »
Yes. This is brilliant.
  • Country: lb
« Reply #7 on: April 09, 2021, 07:06:50 pm »
I just imagined hybrid of solar road and charging road. You park your car on solar road "patch" and you get charged by it.  :-DD
« Reply #8 on: April 09, 2021, 07:44:58 pm »
Only if it's graphene-infused.
« Reply #9 on: April 09, 2021, 07:52:04 pm »
With green energy nanoparticles.
(Whenever someone talks about "green energy", I keep thinking of that movie.)
Offline MikeK
« Reply #10 on: April 09, 2021, 11:29:15 pm »
We already know that roads are very expensive...And there's always people who come up with ways to make them EVEN MORE expensive.
Offline Daixiwen
  • Country: no
« Reply #11 on: April 12, 2021, 07:26:17 am »
It's still missing some blockchain technology
Offline MikeK
« Reply #12 on: April 12, 2021, 12:03:47 pm »
And Bluetooth.
The following users thanked this post: ThreeFriedTransistors
Offline ThreeFriedTransistors
  • The rosin vapours are natural
« Reply #13 on: April 03, 2022, 06:06:53 pm »
And "Smart" features to make it an IoT device
