Crap work happens "in the best of families!"
When I was, for a time, the Electronics Tech at the Chemistry Dept of the University of Western Australia, we had a German built NMR device which incorporated a "RF generator" (actually a transmitter) which, from memory, produced 300watts at around 60MHz.
This device had an interesting fault, in that, every now & then, it started out at full power, as normal, then gradually faded away, making accurate NMR tests impossible.
On investigation, it appeared to have been worked on previously, but none of the parts that had been looked at seemed to have been the cause of the fault.
It turned out that the UWA had obtained it for a reduced, but still substantial price, from the importer, after it had been returned by another institution where it was somehow "no longer needed".
After looking at all the "usual suspects", I was left with the Vcc power supply connection to the RF PCB.
This was bypassed to ground with two sizeable electrolytics in parallel with a couple of much smaller value ceramics.
At first sight, all looked well, but I decided the electros were worth a closer look.
I was ready to assume they were both the same value, but thought "Better check".
One was mounted with the label side facing the metal chassis (they were axial caps), but by dint of a little "butchery", I was able to turn it enough to read the value.
To my surprise, the case of the electrolytic had a "bloody great dent" right where the label was.
Removing that cap, & digging around amongst the random, dusty capacitor spares I found a rather scruffy looking, but suitable, replacement, & all was well.
The question now arises------how did a reputable company allow something like this out of the factory, especially as it looked like there had been a deliberate attempt to conceal the capacitor damage?
"Friday night" or "Monday morning" production run?
Somebody leaving & making an "up yours" statement?
Who knows?
