Author Topic: The opamp buffer - Arrow Electronics style  (Read 4914 times)
Offline BreakingOhmsLawTopic starter
  • Certified solder fume addict
« on: October 12, 2023, 08:50:25 pm »
https://www.arrow.com/en/research-and-events/articles/fundamentals-of-op-amp-circuits
Comedy gold by Arrow Electronics.
"Students might become puzzled"
Ya think?
Offline SiliconWizard
Re: The opamp buffer - Arrow Electronics style
« Reply #1 on: October 12, 2023, 09:22:21 pm »
Absolutely excellent! :-DD
Offline tszaboo
« Reply #2 on: October 12, 2023, 10:38:29 pm »
Silly Arrow. You should always connect the feedback to the + pin!
The following users thanked this post: Warhawk
Offline temperance
« Reply #3 on: October 12, 2023, 11:39:54 pm »
In our school for higher education we had a docent claiming that in an inverting amplifier all currents magically disappears into the inverting input because the other terminal is held at 0 V. So he consistently drew current arrows around such an amplifier pointing towards the inverting input.
Offline thm_w
  • Non-expert
« Reply #4 on: October 13, 2023, 12:31:54 am »
Why the hell are Vs and Ve used to label the input and output? Why not Vin and Vout..  :palm:
Super confusing.
Offline newbrain
« Reply #5 on: October 13, 2023, 08:17:06 am »
Probably from French entrée and sortie.
English is not the only language of this world, luckily.
This does not diminish or excuse the idiotic blunder.
Offline Kleinstein
« Reply #6 on: October 13, 2023, 09:53:53 am »
At least they did not connect the supply - so it may actually work in some cases.
« Reply #7 on: October 13, 2023, 10:26:31 am »
The author apparently is a french marketing manager.
Let's hope he is better at marketing for Arrow's sake.
« Reply #8 on: October 13, 2023, 07:16:52 pm »
Funnily, the example that follows with a resistive divider followed by an opamp buffer is correct, and the rest of the schematics in the article look correct as well.
So it's unclear what happened here.  ::)
Online TimFox
« Reply #9 on: October 13, 2023, 10:18:31 pm »
Not to be confused with (English) "source" and "exit".
Offline AlbertL
« Reply #10 on: October 14, 2023, 04:56:01 pm »
I remember an industrial products web site that had potentiometers listed under "Switches", in a sub-category titled "Variable-Output Switches".
Offline Warhawk
    • Personal resume
« Reply #11 on: October 14, 2023, 05:35:24 pm »
That's why he is a docent and not doing anything remotely close to practical engineering.
Offline The Soulman
  • The sky is the limit!
« Reply #12 on: October 14, 2023, 06:15:08 pm »
Yeah, should send them a email with some negative feedback.
