Author Topic: TsT-Geo "effective protection against electromagnetic and geopathic smog"  (Read 1234 times)
Offline ghorizoTopic starter
Hello, thought it might be interesting to have a look inside one of these ridiculously overpriced gadgets I found on the road.
The other side just has a CR2032 battery.
Product page: http://tst-geo.com
What's actually going on?
How much do you estimate pcb cost?
Online Zero999
  • 0999
When you mean, you found it on the road, do you mean literally dumped, or at a roadside service station shop?
This really belongs in the dodgy technology section, as it's a scam and doesn't do anything. It probably costs a couple of Euros to make at most.
Found it laying on the side of the curb, would never spend a cent for this clear fraud.
I was just wondering what little was going on and how cheap they could produce it.
They are selling these for 230-280 euros..
And yes I should've posted in the dodgy technology section indeed, I forgot there was one. If a mod could move it there would be great.
« Last Edit: June 25, 2021, 10:14:52 am by ghorizo »
Online Zero999
  • 0999
The surface mount semiconductors are marked with codes I don't recognise. It wouldn't surprise me of most of them are unconnected. They might be cheap, fake/used/non-functional parts.  I doubt there's anything worth salvaging. Dispose of it with any other electronic waste, as per your jurisdiction's law.
« Last Edit: June 26, 2021, 04:38:21 pm by Zero999 »
Online Simon
  • Global Moderator
    • Simon's Electronics
someone went to great lengths on the PCB "artwork" with the hexagonal tracks. funny thing is that indeed the one used component would be the resistor at the top for the LED, to use any of the other parts would have "upset" the tri pattern scheme as 3 is a magical number and common in electrical stuff.
Offline daqq
  • Country: sk
    • My site
The following users thanked this post: Zero999
Offline Cyberdragon
Do the vias actually connect through? If so it might be a ring oscillator, meaning it might actually be capable of producing some awful radio noise.
*BZZZZZZAAAAAP*
Voltamort strikes again!
Online Zero999
  • 0999
According to:
https://content.instructables.com/ORIG/F7O/81KO/HRBNDZLH/F7O81KOHRBNDZLH.pdf
Thank you for that reference. It helped me identify some transistors on a relay board I blew up by connecting the power backwards. I shouldn't have assumed the black wire was negative.  :palm: I destroyed an LM7805, which I replaced, but it still didn't work. The relays made a slight noise, but didn't pull in, because the driver transistors had been damaged, which reduced the hFE. Anyway, that reference helped because it saved me reverse engineering this thing, by telling me they're PNP.
