Author Topic: Power bank circuit that let the magic smoke out  (Read 353 times)
Offline Danielradcliff
  • Meow hello I have autism
« on: March 27, 2021, 03:02:30 am »
This power bank circuit was working fine until all of a sudden It irrupt it in sparks and fire  and smoke
This power bank circuit board is from Amazon in the US I’m Sending it back to Amazon to get a new  power bank circuit board  hopefully This is a one time occurrence. Here’s a link to the power bank circuit board on Amazon see what you think about it everyone do you think it Technology doggy or decent  https://www.amazon.com/dp/B08MXM75V1/ref=cm_sw_em_r_mt_dp_EAWAAV71F287ND39RG14?_encoding=UTF8&psc=1
Hello if you notice that I edit my posts a lot it’s just how I think
« Last Edit: March 27, 2021, 03:21:47 am by Danielradcliff »
Meow hello I’m DanielRadcliff
Offline Ian.M
Re: Power bank circuit that let the magic smoke out
« Reply #1 on: March 27, 2021, 04:01:34 am »
There's a datasheet for the SW6106 PMIC that let the magic smoke out here: https://www.waveshare.com/w/upload/e/ed/SW6106_Datasheet_Release_DS008_v1.0.pdf
You can check if component values match the reference design and if your usage was pushing it too close to its rated limits.
« Reply #2 on: March 27, 2021, 04:05:27 am »
Thank you
Online MrMobodies
« Reply #3 on: March 27, 2021, 05:04:22 pm »
Just noticed this:
https://www.amazon.com/dp/B08MXM75V1/ref=cm_sw_em_r_mt_dp_EAWAAV71F287ND39RG14?_encoding=UTF8&p;sc=1
Specification:
Condition: 100% Brand New
Item Type: Power Supply Module
Material: Plastic + PCB
Color: As the Picture Shown
Model: PD18W
Application: For 3.7V Lithium Battery (Parallel Connection)
Input: Type-C Interface Supports PD Protocol 18W (5V3A, 9V2A, 12V1.5A)
Output: Type-C Interface Supports PD Protocol 18W (5V3A, 9V2A, 12V1.5A) Two-Way Fast Charge
Output Blue USB-A Interface: Support QC2.0, QC3.0 Fast Charge (5V2A, 9V1.5A, 12V1.5A Max)
Output White USB-A Interface: Output 5V/2.4A
Size: Approx. 67 x 32 x 10.5mm/2.6 x 1.3 x 0.4in
Note:
When Using More Than 2 Output Ports at the Same Time, The Fast Charge is Triggered By Mistake, All are 5V Output
Not sure what they mean by "triggered by mistake" whether all the outputs are limited to 5v when more than one port is drawing power.
« Last Edit: March 27, 2021, 05:06:32 pm by MrMobodies »
