Author Topic: Solar Freakin' floating panels  (Read 3326 times)
Offline oxcartTopic starter
« on: May 08, 2024, 08:10:42 pm »
Someone forward this to Dave.. :D :D :D
How it started:
How it is going:
https://t.me/intelslava/59387
Offline Bud
Re: Solar Freakin' floating panels
« Reply #1 on: May 08, 2024, 08:14:56 pm »
At least there was no fire  :-DD
Online SiliconWizard
« Reply #2 on: May 08, 2024, 09:02:29 pm »
Nobody loses. ;D
Offline ebastler
« Reply #3 on: May 09, 2024, 09:15:03 am »
Not the same plant though, India != Indonesia.
Offline Marco
« Reply #4 on: May 09, 2024, 11:21:10 am »
Not enough strength to handle the loads and someone clearly screwed up the anchoring. If they made it more light weight and kept it below the surface I doubt it would happen.
« Last Edit: May 09, 2024, 11:24:22 am by Marco »
Online wraper
  • Country: lv
« Reply #5 on: May 09, 2024, 11:38:25 am »
Makes no sense whatsoever. Ho being more lightweight is supposed to help? Not to say keep below the surface?:o
Offline Marco
« Reply #6 on: May 09, 2024, 12:59:59 pm »
If it's flat on the water, it's only the oscillating momentum of the waves which causes forces.
All that structure above the water creating windload just amplifies the required amount of material
« Last Edit: May 09, 2024, 01:07:33 pm by Marco »
« Reply #7 on: May 09, 2024, 02:25:11 pm »
I'm aware of that, for  what i could find i think there's some country mixup, because the only solar freakin' floatin' plant by Masdar is in Indonesia https://masdar.ae/en/renewables/our-projects?&technology=Floating%20Solar%20PV
Online wraper
  • Country: lv
« Reply #8 on: May 09, 2024, 02:30:33 pm »
So how  this has anything to do with weight, not to say more weight = more inertia = it does not move as much. As of below the water, if you want something that produces way less electricity and also overgrows with algae, sure.
Offline ebastler
« Reply #9 on: May 09, 2024, 03:17:57 pm »
Indeed, the Masdar plant is in Indonesia, as exlained in the video you shared. In contrast, the world's largest floating solar plant was built (presumably by some other company) in Madhya Pradesh, India, and was badly damaged in a storm in April. The mixup is on your end.
Maybe they should build some wind turbines instead, since they do seem to have wind in Madhya Pradesh after all...
Offline MrMobodies
« Reply #10 on: May 12, 2024, 03:01:10 pm »
I wonder could that attract animals to loiter on them and use them as a crossing.
Joke: It'd be put out by the water and with the kangroo's turning up in India they could go hopping over them to reach the other side.
« Last Edit: May 12, 2024, 03:11:37 pm by MrMobodies »
Offline Kleinstein
« Reply #11 on: May 12, 2024, 03:35:04 pm »
The idea with PV on water is not so bad, if they have the right places. In some areas land is scare and the solar installation can reduce the evaporation from reservours. On the water the cells are also relatively cool and thus can give good efficiency. It is still not without problems: the wave action is additional stress and birds find nice resting places, so that the panels get dirty in some areas.
I don't see animals using them for crossing the water (usually they are more something for small to medium size lakes, not rivers). The shade may effect the water life, not necessary bad, but a change.
Wind can be a problem on rather large water areas, less with smaller ones.
Having occasionally strong storms does not mean that they get good wind for wind power. Peak wind and average wind not always come together, though exposed places amplify both.
The following users thanked this post: Someone, MrMobodies
Offline Refrigerator
  • Country: lt
« Reply #12 on: May 14, 2024, 12:55:36 pm »
Solar panels benefit from being cooled so placing them on water seems beneficial. I don't know how they would deal with the waves, because, unless the panels are infinitely stiff, there will be flex and possible stress fractures.
But then again people put panels on rooftops where they get beat by rain and wind and sometimes micrometeorites.
Slowing down evaporation would drive up the water temperature, so aquatic life would have to either adapt or die off. But that's assuming the installation is big enough to cause enough change.
I have a blog at http://brimmingideas.blogspot.com/ . Now less empty than ever before !
An expert of making MOSFETs explode.
Offline Kleinstein
« Reply #13 on: May 14, 2024, 04:23:41 pm »
The position on the water is different from installation on a roof or similar. Especially where land is scare or with additional benefit to the lake it can still make sense. An example for this is in singapore.
It may not be the best solution and not a real game changer, but it could still make sense. Way better than solar road ways and similar.
https://www.pub.gov.sg/Public/WaterLoop/Sustainability/Solar/Floating
« Reply #14 on: May 14, 2024, 09:09:33 pm »
We need even more of these projects for sure. :-DD
  • Country: lt
« Reply #15 on: May 15, 2024, 10:16:50 am »
There is nothing worse than solar freaking roadways  :-DD
