Author Topic: The opamp buffer - Arrow Electronics style  (Read 4342 times)
Offline BreakingOhmsLawTopic starter
  • Certified solder fume addict
« on: October 12, 2023, 08:50:25 pm »
https://www.arrow.com/en/research-and-events/articles/fundamentals-of-op-amp-circuits
Comedy gold by Arrow Electronics.
"Students might become puzzled"
Ya think?
Offline SiliconWizard
Re: The opamp buffer - Arrow Electronics style
« Reply #1 on: October 12, 2023, 09:22:21 pm »
Absolutely excellent! :-DD
Online tszaboo
« Reply #2 on: October 12, 2023, 10:38:29 pm »
Silly Arrow. You should always connect the feedback to the + pin!
The following users thanked this post: Warhawk
Offline temperance
« Reply #3 on: October 12, 2023, 11:39:54 pm »
In our school for higher education we had a docent claiming that in an inverting amplifier all currents magically disappears into the inverting input because the other terminal is held at 0 V. So he consistently drew current arrows around such an amplifier pointing towards the inverting input.
Some species start the day by screaming their lungs out. Something which doesn't make sense at first. But as you get older it all starts to make sense.
Offline thm_w
  • Non-expert
« Reply #4 on: October 13, 2023, 12:31:54 am »
Why the hell are Vs and Ve used to label the input and output? Why not Vin and Vout..  :palm:
Super confusing.
Online newbrain
« Reply #5 on: October 13, 2023, 08:17:06 am »
Probably from French entrée and sortie.
English is not the only language of this world, luckily.
This does not diminish or excuse the idiotic blunder.
Online Kleinstein
« Reply #6 on: October 13, 2023, 09:53:53 am »
At least they did not connect the supply - so it may actually work in some cases.
« Reply #7 on: October 13, 2023, 10:26:31 am »
The author apparently is a french marketing manager.
Let's hope he is better at marketing for Arrow's sake.
« Reply #8 on: October 13, 2023, 07:16:52 pm »
Funnily, the example that follows with a resistive divider followed by an opamp buffer is correct, and the rest of the schematics in the article look correct as well.
So it's unclear what happened here.  ::)
Offline TimFox
« Reply #9 on: October 13, 2023, 10:18:31 pm »
Not to be confused with (English) "source" and "exit".
Offline AlbertL
« Reply #10 on: October 14, 2023, 04:56:01 pm »
I remember an industrial products web site that had potentiometers listed under "Switches", in a sub-category titled "Variable-Output Switches".
Offline Warhawk
    • Personal resume
« Reply #11 on: October 14, 2023, 05:35:24 pm »
That's why he is a docent and not doing anything remotely close to practical engineering.
Online The Soulman
  • The sky is the limit!
« Reply #12 on: October 14, 2023, 06:15:08 pm »
Yeah, should send them a email with some negative feedback.
