Author Topic: Unlimited Power from Graphene and Brownian Motion  (Read 1146 times)
Offline srruhl3701
« on: October 02, 2020, 09:30:51 pm »
https://phys.org/news/2020-10-physicists-circuit-limitless-power-graphene.html
According to Kumar, the graphene and circuit share a symbiotic relationship. Though the thermal environment is performing work on the load resistor, the graphene and circuit are at the same temperature and heat does not flow between the two.
That's an important distinction, said Thibado, because a temperature difference between the graphene and circuit, in a circuit producing power, would contradict the second law of thermodynamics. "This means that the second law of thermodynamics is not violated, nor is there any need to argue that 'Maxwell's Demon' is separating hot and cold electrons," Thibado said.
« Last Edit: October 03, 2020, 12:52:34 am by srruhl3701 »
Online Gyro
Re: Unlimited Power from Graphene and Brownian Motion
« Reply #1 on: October 03, 2020, 07:48:33 pm »
err... https://www.eevblog.com/forum/dodgy-technology/physicists-build-circuit-that-generates-clean-limitless-power-from-graphene/
EDIT: Actually it looks as if you were there first and Dave posted without reading yours!  :)
« Last Edit: October 03, 2020, 07:55:18 pm by Gyro »
Chris
"Victor Meldrew, the Crimson Avenger!"
The following users thanked this post: srruhl3701
Offline Cyberdragon
« Reply #2 on: October 04, 2020, 06:55:50 am »
Yes, but we shant call our master out on reposting. :-X
*BZZZZZZAAAAAP*
Voltamort strikes again!
Offline bson
« Reply #3 on: October 17, 2020, 08:43:38 pm »
Just don't short the 'unlimited' power terminals or the infinite instantaneous current will end the universe.
Offline anovickis
« Reply #4 on: February 26, 2021, 09:15:52 pm »
I wonder if you can put a load on this generated AC or it just exists because they didn't ground the scope probe with which the measurements are taken.
I can go one simpler - all I have to do is turn up the sensitivity on the scope, and I have power from the air, who needs the graphene.
Offline Refrigerator
  • Country: lt
« Reply #5 on: February 28, 2021, 11:49:10 am »
"Woah, what's this mysterious 50Hz voltage appearing on my scope probe, have i discovered unlimited power?!?!" is probably what you'd expect people like that to believe.
 :-DD
I have a blog at http://brimmingideas.blogspot.com/ . Now less empty than ever before !
Online SiliconWizard
« Reply #6 on: February 28, 2021, 04:52:20 pm »
Would the University of Arkansas have sunk so low though?
