Author Topic: Jump starter cable - really thick = really good...  (Read 490 times)
Offline daqq
  • Country: sk
    • My site
« on: August 19, 2019, 07:36:45 am »
Copper's apparently cheaper than rubber :)
814524-0
Offline Raj
  • Country: in
  • Self taught, experimenter, noob(ish)
Re: Jump starter cable - really thick = really good...
« Reply #1 on: August 19, 2019, 07:38:21 am »
I would buy it, but not as a jumper cable, there's no chance of damaging that in workshop.... Link to the shop please  :-DD
Offline Rerouter
« Reply #2 on: August 19, 2019, 07:41:57 am »
more common than you think, even found the same in welding ground cables, trimmed back the heatshrink off the where the wire was joined, and it was barely thicker than 3mm, with like 10mm of insulation thickness.
Its part of why they say to not run high current loads over extension leads, if its not from a hardware store, your probably not getting a full mains current rated lead,
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: August 19, 2019, 07:54:54 am »
Even worse, when it's CCA, or even CCsteel.
Seven Transistor Labs, LLC
Offline David Hess
  • DavidH
« Reply #4 on: August 19, 2019, 04:46:43 pm »
That sort of thing is more common than it should be.  I am surprised there are not billboards with the slogan, "Marketing is Truth".
Online T3sl4co1l
« Reply #5 on: August 19, 2019, 05:08:04 pm »
CONSUME
;D
Or there's a pub near me that always has the sandwich board outside, reading "EAT".  I always find it a little amusing, given the above context.
