Since we have a lot of banks as clients - it's almost funny how so many of them have very up to date IT - until you get to the core banking app. Then it's old, hosted stuff running on antique mainframes. Just when you thought you saw the last 3270 terminal emulator - then you see what runs on the teller workstations.
One of my clients has a division that buys and sells loans. All the funds transfers involved are wire transactions. Until a couple of years ago when I wrote an application for them, they were doing all these wire transfers manually - can be hundreds per day. Crazy. The file format for an automated wire transfer is quite archaic, but is not difficult to create and it is very well documented. Even worse were the incoming ones - someone had to read through the transfer report and then manually update the information in their primary application. Not only was it slow and time consuming, the potential for error was rather high. Now it's all automated, both ways, and they handle many more transactions per day.
Hmm, I did find some T connectors in the back room, wonder if I have enough to make a desktop pet. I don't do any RF stuff so I never thought to keep that stuff around once everywhere I worked switched to UTP cabling. I think there's a spool of coax in the back too. Never forget the one time a client called us out for a problem with a workstation connecting to the network. Go to the server/wiring room, and coming out of one of their UTP hubs was this run of flat phone cable. Two of us just looked at each other, and then said to the client "I assume this is the cable going to the workstation with a problem?" Not only was it the wrong type of cable, even if it WAS proper Cat 3 cable, it was far longer than the distance limit with UTP at the time, because it went up some 20 feet to the ceiling, and came down at the workstation end, in addition to being about as far away as you could get in this huge warehouse/manufacturing plant. And freely strung across whatever else was up in the rafters - everything from 120V to 48V power lines, fluorescent lighting fixtures, etc.
