Author Topic: Wooden electrolytic capacitors  (Read 11083 times)
Online Brumby
Re: Wooden electrolytic capacitors
« Reply #25 on: July 01, 2018, 03:00:59 am »
Hrrrumphhh.  Ovens.
Ovens powered by gas or electricity are the devil.  Gas ovens contaminate the capacitor material and electric ones spin the electrons around into quasi-homopolar states.
Do what I do for the best results - a moderated solar furnace.  The near-to-perfect parallel rays of the sun ensure proper electron alignment and is as natural as you can get!
As for the mahogany stain, I find that over accentuates low frequencies a tad more than I like.  A teak stain is better, IMHO.
« Last Edit: July 01, 2018, 03:04:13 am by Brumby »
Offline CJay
« Reply #26 on: July 01, 2018, 09:39:05 am »
EDIT: They have an excellent affinity for the note B2... ;D
I'd have thought more for B5
Offline amyk
« Reply #27 on: July 01, 2018, 05:10:19 pm »
One of the few audiofool mods that likely does make a significant difference to the sound... :-DD
Offline Cyberdragon
« Reply #28 on: July 01, 2018, 05:28:31 pm »
aww, I thought you guys would get the joke ::)
B2 is about 123Hz which is close to the 120Hz you would get in certain countries from a FULL BRIDGE RECTIFIER when you put your newly destroyed (dried up and nonfunctional) audiofool caps across it. >:D
EDIT: It would be a G2 for everyone else.
« Last Edit: July 01, 2018, 05:30:14 pm by Cyberdragon »
*BZZZZZZAAAAAP*
Voltamort strikes again!
Offline BillB
« Reply #29 on: July 01, 2018, 09:51:05 pm »
It's a hideous triumph of form and function
The following users thanked this post: fonograph, bd139
Offline Raven Luni
  • Country: scotland
« Reply #30 on: July 01, 2018, 10:29:52 pm »
It wooden work if you ask me :p
(sorry for having to be the person who said it)
Offline Cyberdragon
« Reply #31 on: July 01, 2018, 10:54:40 pm »
How much wood would a wood cap chuck if a wood cap would go bang? >:D
*BZZZZZZAAAAAP*
The following users thanked this post: Brumby, bd139, Raven Luni
Offline ArthurDent
« Reply #32 on: July 01, 2018, 11:56:25 pm »
I have to admit I've done something similar to the wooden cap described but not for the same reason. I was restoring an old Atwater-Kent battery powered radio and some of the coupling caps were dead. I wanted to keep the radio looking as original as possible so I melted the wax end seals and removed the capacitor guts. I then placed a modern smaller physical sized cap of the same value inside the old shell and refilled the ends with bee's wax and the 'new' cap looked exactly like the old one-but this one worked.
Offline chris_leyson
  • Country: wales
« Reply #33 on: July 02, 2018, 12:19:20 am »
@ArthurDent. Nice one, I've seen quite a few radio restorers do the same thing. Waxed paper caps are not too difficult you just have to warm them up a little bit and they come apart quite easily. Also good for holding tuning slugs in place, less danger of breaking the slug.
Offline bitseeker
« Reply #34 on: July 02, 2018, 12:26:57 am »
Yeah, restuffing caps to preserve the aesthetics of vintage gear is usually OK because the replacement capacitor's enclosure isn't compromised, unlike these wooden abominations. (You do have to consider any potential heat buildup issues, though, depending on the role the capacitor plays in the circuit.)
Offline mtdoc
« Reply #35 on: July 02, 2018, 01:04:27 am »
Even without any functional improvement, I can appreciate  the improved asthetics, but now he’s added a new cap failure mode: Termites!
The following users thanked this post: BrianHG
Offline bitseeker
« Reply #36 on: July 02, 2018, 01:09:07 am »
Yea for nature!
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #37 on: July 02, 2018, 04:40:46 am »
How to unsee this  :o.
Offline bitseeker
« Reply #38 on: July 02, 2018, 05:48:32 am »
I don't think you can unsee it. You'll just have to settle for replacing that visual with something more heinous.
Offline texaspyro
« Reply #39 on: July 02, 2018, 06:04:32 am »
Eye bleach... and lots of it.   Followed by a brain bleach steam cleaning chaser.
Offline bd139Topic starter
« Reply #40 on: July 02, 2018, 07:02:43 am »
I have a little take to tell on this.
I had a friend many years ago who was into the vintage HiFi stuff and did this. So we’re sitting there admiring his latest restoration while he explains what he had to do, including restuffing the caps. So he puts on the amp and slaps on some Clapton. We nod approvingly until I hear a little hum. This was explained away as something that needed fixing.  It got louder. We started getting worried. He said no it was supposed to do that, clearly in denial. Boom like you’ve never heard! Bzzzt! Smoke comes pouring out from behind it.
So it turned out one of the caps had given out inside a restuff. He’d used 85oC ones with no ripple rating and glued them hard into the old can. Turns out this had turned into a large oven crossed with a pipe bomb which went off neatly plinking half the tubes in the unit at the same time  :palm: ...
He solders new caps under the chassis now.
Offline bitseeker
« Reply #41 on: July 02, 2018, 07:25:15 am »
Yeah, Paul Carlson puts new caps underneath as well. Seems a good idea, indeed.
Online tggzzz
« Reply #42 on: July 02, 2018, 09:13:09 am »
Has anyone tried to persuade "DHTRob" that he could make further improvements if he used the same technique on the valves/tubes in his amplifiers?
« Reply #43 on: July 02, 2018, 11:49:38 am »
I would actually pay money to see him try.
« Reply #44 on: July 02, 2018, 12:15:55 pm »
You buy the tickets, I'll bring the popcorn and beer. Deal?
« Reply #45 on: July 02, 2018, 02:28:07 pm »
It’s a deal  :-+
No one bring a fire extinguisher :)
Offline Cyberdragon
« Reply #46 on: July 02, 2018, 04:04:46 pm »
Gotta love a good wood-fired barbie. Lovely smells... >:D
EDIT: Who's got the steak and marshmallows?
*BZZZZZZAAAAAP*
« Reply #47 on: July 02, 2018, 05:35:33 pm »
The best thing is that he's using tropical hardwoods. I've been privileged to know with someone who used to work in those woods and used the too small offcuts as fuel for the workshop fire. Some of that stuff smells amazing when it burns. (Some is toxic when it burns, so it pays to know your woods before trying this out.)
Offline texaspyro
« Reply #48 on: July 02, 2018, 06:25:16 pm »
He should have used Clapton tape to secure the caps...   :-DD
Offline b_force
    • One World Concepts
« Reply #49 on: July 02, 2018, 08:18:21 pm »
Maybe he also wouldn't shot the sheriff than.
