Author Topic: Component Attributes Editor?  (Read 5677 times)
Offline Jeroen3Topic starter
  • Embedded Engineer
    • jeroen3.nl
« on: September 16, 2016, 02:07:58 pm »
Is there a way to edit component attributes as a table view?
I can use an ULP to export them to excel... but then I'll be adding numbers and specs that really should be in the design file (or even lbr).
Or do I need to ulp my own?
Offline technotronix
    • PCB Assembly
Re: Component Attributes Editor?
« Reply #1 on: September 28, 2016, 02:05:34 pm »
may be we can do it by using frame ( frames.lbr library).
Offline Josephine85
« Reply #2 on: October 27, 2016, 07:59:30 am »
Hm i don´t know if you can. On the website i found just these two mentioned in the FAQ (https://cadsoft.io/support/faq/).
Renumber components in the layout — cmd-renumber.ulp
Access to Farnell's components data base — designlink.ulp
Maybe the data base is something you could use, but i never tried it.
Offline jgarc063
« Reply #3 on: November 02, 2016, 07:54:30 pm »
Hi Jeroen,
I hope you're doing well. There currently isn't a ULP that can give you a table view of all of the components in your design with their respective attributes that is editable.
However the BOM-EX download on our website has a ULP that can make it easy to assign the same attribute to multiple parts. You can also add attributes in the library.
If I've misunderstood what you are trying to do please correct me.
Best Regards,
Jorge Garcia
    • PCB Assembly
« Reply #4 on: December 30, 2016, 07:53:34 am »
Did you try to do it using the framework?
Offline IanJ
  • Country: scotland
  • Full time EE & Youtuber
    • IanJohnston.com
« Reply #5 on: December 30, 2016, 09:37:24 pm »
Try:
http://www.bobstarr.net/pages/downloads.html
BOM-EX might do what you need.
Ian.
Ian Johnston - Original designer of the PDVS2mini || Author of the free WinGPIB app.
Website - www.ianjohnston.com
YT Channel (electronics repairs & projects): www.youtube.com/user/IanScottJohnston, Twitter (X): https://twitter.com/IanSJohnston
Offline richardlawson1489
    • PCB Assembly
« Reply #6 on: January 31, 2017, 11:50:51 am »
This may work.
