Author Topic: Difference in footprit  (Read 2274 times)
Offline R4v3n5
  • Country: si
« on: August 10, 2017, 04:58:08 pm »
Hello, so I am designing something (RGB LED matrix), and as I am using some common anode RGB LEDs I found a SparkFun library that has them.
So in the library the footprint has some space in between the pads, but on the pcb they are touching together.
Why is it different and how can I fix this.
Offline jgarc063
Re: Difference in footprit
« Reply #1 on: August 10, 2017, 05:55:48 pm »
Hi R4v3n5,
I hope you're doing well. You are getting bit by restring, this is relatively common. You basically have to adjust the restring settings on your board to allow your library settings to win and take effect.
For a full explanation see this blog post:https://www.autodesk.com/products/eagle/blog/what-you-didnt-know-about-eagle-restring/
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Autodesk Support
The following users thanked this post: R4v3n5
Offline R4v3n5
  • Country: si
« Reply #2 on: August 10, 2017, 06:03:14 pm »
Thank you, that solved my problem.
Offline ebastler
« Reply #3 on: August 10, 2017, 06:19:01 pm »
Thanks, Jorge!
Quick note: In the explanation you linked to, the images for figures 2 and 3 need to be swapped to make the text even clearer.  ;)
Offline jgarc063
« Reply #4 on: August 14, 2017, 04:12:04 pm »
Thanks ebastler,
I'll report that to have it fixed.
Best Regards,
Jorge Garcia
