Author Topic: Digital_and_Analog_Ground  (Read 1971 times)
Offline Write_to_Smokegenerator
  • Country: at
  • enthused hobbyist
« on: September 11, 2012, 07:06:30 pm »
Hi
I've run into a Small Problem.
Currently I'm designing a Circuit where I have a Digital and an Analog Ground. The Problem is to Connect both because if I use the AGND Symbol, the DRC puts out some warnings, normally i would ignore this, if I would print the circuit at home, but this circuit will be manufactured professionally.
My current sollution to this Problem is really dirty I just use a 0 OHm Resistor but I don't want to use this.
I would appreciate some help ;)
Wondering about my Username have a look at:
http://www.finkewitz.de/uwe/witze/ANSIASM.txt
Offline Psi
Re: Digital_and_Analog_Ground
« Reply #1 on: September 11, 2012, 10:56:19 pm »
  • Country: at
  • enthused hobbyist
« Reply #2 on: September 12, 2012, 06:56:38 am »
Thanks, helped a bit I'll that workaround with teh renaming, maybe this will work, if not i'll stick with the 0 OHM Resistor.
cheers.
