Author Topic: DIP package has PAD or Via  (Read 5033 times)
Offline RoadRunner
« on: December 27, 2011, 12:36:48 pm »
hi
   i am designing a double layer pcb which has a DIP package  microcontroller  and few smd ic
i want to know that the pad which are used by all the dip package they are via or just pads ( i mean they will appear on a single layer)
if they are just pad then how to convert them to via so that they will appear to both of the layer
what are things that i should i keep in mind while generating the Gerber files
Offline Psi
Re: DIP package has PAD or Via
« Reply #1 on: December 27, 2011, 12:53:06 pm »
What PCB package are you using?
alm
  • Guest
« Reply #2 on: December 27, 2011, 04:29:09 pm »
According to my crystal ball it's Eagle.
Offline 8086
    • Circuitology - Electronics Assembly
« Reply #3 on: December 27, 2011, 04:31:24 pm »
DIP pads appear on both sides and are plated through. At least they do when I use them. I use Sparkfun's Eagle library for common packages like these.
« Last Edit: December 27, 2011, 04:35:29 pm by 8086 »
Offline RoadRunner
« Reply #4 on: December 27, 2011, 05:05:07 pm »
i m using eagle 5.11
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #5 on: December 27, 2011, 05:11:24 pm »
If it has component lead through it, it's a pad. If it's only to ocnnect between layers, it's a via.
The only differences are that vias tend to not have openings in the solder resist layers, and they can be moved around by the routing process (auto or manual).
Day Job: Mostly LEDs
Offline RoadRunner
« Reply #6 on: December 27, 2011, 07:16:49 pm »
Sir
     i want  though hole pad to appear on both side of the pcb and connected internally (via)
alm
  • Guest
« Reply #7 on: December 27, 2011, 08:43:09 pm »
Did you read the post by mikeselectricstuff just before your post? Both pads and vias are plated through in two layer designs.
Offline RoadRunner
« Reply #8 on: December 28, 2011, 12:57:36 pm »
Thank you sir
 i helped me a lot
