Author Topic: Eagle Board Layout Assistant  (Read 2086 times)
Offline Jon Chandler
    • Throw Away PIC
« on: May 19, 2013, 08:21:37 pm »
Layout out boards to fit enclosures can be difficult, especially the cross-shaped boards designed to use the maximum area of an enclosure.  The make the process easier, I created the Eagle Board Layout Assistant using Visual Basic.  It should run on any Windows computer and generates a script file to create the board in Eagle.  No installation is required.  VB6RUN.DLL is required which is usually on computers running Microsoft applications.
Information and instructions for using the program may be found here.
Offline stryker
Re: Eagle Board Layout Assistant
« Reply #1 on: May 20, 2013, 10:06:53 am »
Thanks Jon.  I've downloaded this and bookmarked that instructions page.  Looking forward to giving this a crack.
Cheers ! Geoff
Offline free_electron
    • SiliconValleyGarage
« Reply #2 on: May 20, 2013, 01:55:48 pm »
Simply make a tool that can slice the 3d model (step file), shrink the outline and export that as a layer. The you really have the right contour.
Offline Afrotechmods
    • Afrotech
« Reply #3 on: May 22, 2013, 10:34:20 pm »
This is extremely clever! Well done Jon.
