Author Topic: Eagle Part count  (Read 2702 times)
Offline richcj10
Eagle Part count
« on: April 28, 2014, 04:48:13 am »
Is there any way to tell the user how many parts in total are on the board?
Offline zapta
Re: Eagle Part count
« Reply #1 on: April 28, 2014, 04:56:37 am »
Try Tools / Statistics menu command while the board is opened.
Drain the swamp.
Offline stryker
« Reply #2 on: April 28, 2014, 04:59:33 am »
That's cool.  I did not know that - the elements tab has a total.  8)  This must be the thing I'll be learning today.
My suggestion was going to be use File / Export / Part List, send it to Notepad++ or some editor, cut off the headers and the final blank line and the line count is your part count.
Your way is far quicker,
Geoff
Offline Skimask
« Reply #3 on: April 28, 2014, 05:25:02 am »
run count.ulp
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Offline zapta
« Reply #4 on: April 28, 2014, 06:41:20 am »
... or renumber the parts and sum the max numbers of each prefix ;-)
Drain the swamp.
