Author Topic: Eagle PCB for 4-layers add 2; 3Layers _Restrict for internal two layers.  (Read 2359 times)
Offline Jefferson
Hi All!
There is a need in Eagle PCB for 4-layers add 2; 3Layers _Restrict for internal two layers.
That does not exist for the installation.
Create a new layer and name 2Layers _Restrict not a problem,
but as he screwed function _Restrict, ... can anyone know?
Thanks.
Offline jgarc063
Re: Eagle PCB for 4-layers add 2; 3Layers _Restrict for internal two layers.
« Reply #1 on: November 21, 2016, 05:06:07 pm »
Hello Jefferson,
I hope you're doing well. There are currently now restrict layers available for the inner layers. Naming a layer with the word restrict in it, won't do anything.
The best that you can do at the moment is draw a cutout polygon on the inner layers to not fill part of a polygon. This is pretty easy to do, just draw a polygon and then look at it's properties set the fill type to cutout.
Let me know if there's anything else I can do for you or if I have misunderstood the question.
Best Regards,
Jorge Garcia
Offline Jefferson
« Reply #2 on: November 22, 2016, 10:48:25 am »
Jorge thanks for the answer. You understand me perfectly and accurately answered.
It works.
