Electronics => PCB/EDA/CAD => Eagle => Topic started by: IanJ on June 02, 2014, 05:40:10 pm
Hi all,
V6.6.0 is out. Here's the update log.
Ian.
Release notes for EAGLE 6.6.0
* Miscellaneous:
- Member value of UL_ATTRIBUTE now always returns the attribute's value
(also if it's from an instance, where the value is always inherited from the
part attribute).
- Added missing documentation on member xrefpart of UL_SCHEMATIC object.
- If a ULP is started from a wire context menu, the wire's selection state
(first, second or both endpoints) can now be queried in the ULP with ingroup().
- Improved messages for ULP function neterror() in case of SSL error(s).
Added a note on SSL errors to ULP net functions in help.
- Improved help of TEXT regarding the vector font setting.
- Added SET parameter Option.UnpopulatedMarkScaling to allow scaling down
the mark of not populated parts in the current assembly variant.
- Allow upper/lowercase renaming of an assembly variant.
- Display of a warning with cancel option before a drawing from an older
version (before version 6) gets overwritten.
- Added new ULP function sleep().
- Library update: Information to the user about devicesets that are used in
schematic but can't be found in the corresponding update library.
- Added a restriction note in help on ingroup() in relation with userdefined
context menus.
- Update in help for maximum sizes related to pads, smds, vias, wires,
polygons and holes from 0.51602 inch to 200 mm and for board size from
1600x1600mm to 4000x4000mm.
- Added a note in help on XML attribute order on ULP functions for XML.
- New ULP Felicitas_PCBSim.ulp which creates an interface to PCBSim,
a simulation tool for signal integrity analysis.
- If an assembly variant is being defined for a part with library attribute
'VALUE' the variant value is now set according to this attribute.
- New ULP EagleIDFExporter.ulp. It allows the export of an EAGLE board
to 3D IDF format for further processing in a 3D CAD system. See also
EagleIDFExporterInstructions.pdf in doc folder.
* Bugfixes:
- REPLACE with devices containing attribute VALUE: Update of part value
accordingly for all cases.
- Avoid misinterpretation of cutout polygons in packages as arbitrary pad shape.
- Fix for mouse support for WACOM tablet driver.
- Fix for swallowing of backslashes in TEXT command invoked from command line.
- Fix for erroneous changing of dimension endpoints in MOVE command if selected
by ctrl-click.
- Fixed possible ignoring of prerouted segments by the autorouter (with possible
DRC errors).
- Fixed unjustified message about supply layers if updating drawings of an
older EAGLE version.
- Avoid duplicate contact references in the signal if connecting an implicitly
connected power pin to this net explicitly.
- Fixed handling of oversized description lines in the XML drawing file.
- Fixed an occasional hangup of ULP dialogs if an additional confirmation
dialog has been canceled.
- Fix for using the proper net class while subtracting wires of pads with
"Arbitrary Pad Shapes" from polygons.
- Fixed missing message about insufficient number of contacts if adding a symbol.
There was a problem if multiple contacts were connected to the same pin.
- Fixed CUT (COPY) in schematic if a ULP used setgroup() on other sheets.
- Fix for occasionally not displayed images in HTML descriptions.
- Fixed loss of parameters for Autorouter default optimize passes if updating
files to version 6.
- Ensuring proper update for values of assembly variants after
CHANGE PACKAGE/TECHNOLOGY in case of parts without user value by adapting
it to the corresponding device name.
- Fix for inconsistency after library update if a new device attribute
collides with an existing schematic attribute.
- Fixed skipping polygon wires with zero length but different curve values
while loading drawings.
- ULP function dlgRealEdit: Corrected warning if valid range is violated.
- Fix for context menu function 'Open Device' for instances and elements in
case of special package variant names.
- Fix for erroneous inconsistency warning after creation of a board from schematic
if the current assembly variant is not the default one.
- Fixed unintended execution of the 'if' statement in ULPs if there was already
an exit() in the 'if' condition.
- Fix for showing a signal in rectangle mode (command 'SHOW @') if it only
consists of a contact reference to a pad or SMD.
- Fixed SPLIT on polygon wires; under certain conditions a wire could change
to zero length and corrupt the polygon.
- Fix for inconsistency after library update with existing assembly variants
for device change from 'Value Off' to 'Value On' or name changes of the
package variant or technology.
