Author Topic: EagleCAD v7.1 crashes on Windows10  (Read 5078 times)
Offline DiTBho
« on: May 27, 2021, 02:31:45 pm »
I have a professional license, it worked very well on laptop with Windows XP, I have recently updated to Windows 10 and now when I try to move an object on the PCB-editor the program crashes without any reason.
Anyone has experimented this issue?
I have a lite license for EagleCAD v7.5. No problem with Windows 10.
A colleague has a professional license for EagleCAD v6.6. No problem with Windows 10.
I don't really know  :-//
Offline Karel
Re: EagleCAD v7.1 crashes on Windows10
« Reply #1 on: May 27, 2021, 06:10:55 pm »
Always use the latest patch version for a major version.
In your case that's:
http://web.cadsoft.de/ftp/eagle/program/7.7/eagle-win64-7.7.0.exe
Try again and see if it fixes the problem.
Offline DiTBho
« Reply #2 on: May 27, 2021, 06:58:17 pm »
The 7.7.0.exe perfectly works, but it doesn't accept the license, it says it's "lite version" instead of "professional".
Offline Karel
« Reply #3 on: May 27, 2021, 07:28:27 pm »
That's weird. The license is valid for all 7.x.x versions. You'll have to contact the supportdesk.
Try re-installing the license as per the instructions you received together with your license key.
Offline DiTBho
« Reply #4 on: May 27, 2021, 09:34:46 pm »
Wow, it worked!!! Thank you so much  ;D
