Author Topic: Holes are just gone  (Read 1607 times)
Offline conducteur
Holes are just gone
« on: December 30, 2014, 07:19:17 pm »
Even if i turn all layers on, my holes ar gone!!!!
Offline gaddra
Re: Holes are just gone
« Reply #1 on: January 02, 2015, 03:07:50 am »
The holes are definitely there, you can see the diamond drill symbol. Check the diameter of the hole.
Offline conducteur
« Reply #2 on: January 07, 2015, 01:14:42 pm »
I don't see them anymore... I think they're still there , but you can't see them. Have a look at the RJ12 connectors. Normally the green part is just the copper ring to solder on with a hole in the middle.
Offline philpem
  • That Sneaky British Bloke
« Reply #3 on: January 31, 2015, 12:41:15 am »
Options -> Set
Misc tab.
Under "Display Mode" you have two options: "No Drills" is what you probably have it set to now. "Real" shows you the pads with the drill holes in place, and is probably what you want.
Phil / M0OFX -- Electronics/Software Engineer
"Why do I have a room full of test gear? Why, it saves on the heating bill!"
