Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
Eagle
How I can import gerber?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: How I can import gerber? (Read 2864 times)
fxr
Contributor
Country:
on:
December 26, 2019, 07:27:11 pm »
Hello everyone!
I have problem with import the gerber files into Eagle v7.5
After import the TOP layer I got corrupted image like attached screenshot.
Gerber viewer (Gerbv) show the TOP layer without any problems.
How can I make the correct import in the Eagle ?
Can I convert through another program?
Logged
Quarlo Klobrigney
Frequent Contributor
Country:
This Space For Rent
Re: How I can import gerber?
Reply #1 on:
December 26, 2019, 08:51:15 pm »
What did you use to make it? Can you see it in a third party Gerber viewer?
Logged
Voltage does not flow, nor does voltage go.
fxr
Contributor
Country:
Reply #2 on:
December 26, 2019, 11:22:24 pm »
I don't know what application this file was made of.
I can view this gerber file in gEDA Gerber Viewer.
Logged
Quarlo Klobrigney
Country:
This Space For Rent
Reply #3 on:
December 26, 2019, 11:44:43 pm »
So what is your goal to view it in Eagle?
I have 7.3, if you want me to give it a try, let me know. I have never imported a Gerber in eagle. How are you doing it in the first place?
Logged
fxr
Contributor
Country:
Reply #4 on:
December 27, 2019, 01:20:13 am »
I want to make a small changers the gerber file.
My Eagle Cad version above is 7.5, but it not have many options of import params.
You can select units (mm in my case) and needed layer for import.
Logged
Quarlo Klobrigney
Country:
This Space For Rent
Reply #5 on:
December 27, 2019, 01:26:42 am »
Do you have the original Eagle files? Just fix them there and re-export.
Logged
fxr
Contributor
Country:
Reply #6 on:
December 27, 2019, 02:26:07 am »
No, I not have source files.
If I had the source files then I would just make all the necessary changes in the Eagle Cad without import gerber files.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Eagle
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
