Author Topic: How to avoid many DRC width errors when panelizing ?  (Read 1637 times)
Offline JacquesBBB
« on: September 26, 2015, 09:38:45 am »
Dear All,
I am trying to cramp as much design I can in a 100mmx100mm PCB  to reduce costs.
I have properly made  each  design with no  DRC errors,
and then used the panelized ulp procedure to made the designs adequate for panelizing.
But when I import several on them in my 100mmx100mm  new board design,
I got a huge amount of width errors, whatever the option I take.
Can you help ?
Thanks
Offline Karel
Re: How to avoid many DRC width errors when panelizing ?
« Reply #1 on: September 27, 2015, 01:48:17 pm »
You'll get more and better help if you post your questions in the official Cadsoft Eagle forum: http://www.element14.com/community/community/cadsoft_eagle/forums/
The difference between theory and practice is less in theory than
the difference between theory and practice in practice.
Expensive tools cannot compensate for lack of experience.
Offline kizzap
« Reply #2 on: October 02, 2015, 10:59:26 am »
What are the DRC errors? there can be quite a few...
Common ones are net names, being the same, or part names being the same.
otherwise it may have something to do with the DRC rule setup not being correct.
<MatCat> The thing with aircraft is murphy loves to hang out with them
<Baljem> hey, you're the one who apparently pronounces FPGA 'fuhpugger'
Offline matseng
    • My Github
« Reply #3 on: October 02, 2015, 12:09:15 pm »
Net names and stuff like that are ERC errors, not DRC....
OP said width errors - I guess that he failed to load the .dru file for the panelized board. The default dru have much larger min-widths than the common cheap fab houses.
Offline JacquesBBB
« Reply #4 on: October 11, 2015, 05:56:53 pm »
I had not much help from the Eagle forum.
There is something I  still do not understand. The error are width errors.
I have set up each individual circuit board with a given .dru that gathered my setups.
I had then no errors.
Then I gathered several circuit in a single board with the same .dru file for the DRC setting.
Each time I added a  circuit, I verified  the DRC. I had no errors, except on one
where I had dozens of  width errors.
I did not understand, and
I finally send the  gerber files despite these errors.
