Author Topic: How to layout power rails?  (Read 401 times)
Offline ryanmills
« on: October 09, 2019, 05:49:30 pm »
I'm trying to layout some power rails but eagle is adding its masks around connections (for scale those are 1210 caps). I thought I could do this just like I would a ground pour. But as you can see its gaping the SMD connections . And some like the output tab on the regulator are just cut off. I cant even directly connect the center pin to the tab directly. I assume this is due to the masks in the parts but is there a way to override this? Or a I creating the rail the wrong way? I am using the polygon tool and naming it for the single name like +5V, GND, etc. Is that the correct way? I would really just like the whole pad to be right on the rail without a mask and these tiny traces.
Offline ryanmills
Re: How to layout power rails?
« Reply #1 on: October 09, 2019, 05:54:26 pm »
Ohh its the thermals settings. Right after I posted this I thought of a better way to google. For anyone who finds this, read here: http://dangerousprototypes.com/blog/2012/07/18/eagle-polygons/
