What are the mains reasons, if any, that Eagle falls short of top packages like Altium?
..Eg does Eagle do multiple diff pair bus routing?
..does Eagle do online rule checking? (ie it stops you, or indicates to you, that you are moving say a resistor pad to close to a different net copper track etc?)
..does Eagle have a component "Pusher".
If i get stuck with Eagle, i can google the problem, and the answer to that problem is instantly there.....this is not the case with many other packages , since they seem to be quite "private softwares"...would you agree that this is Eagle's great advantage over all others?
