EDA => Eagle => Topic started by: glatocha on June 30, 2013, 07:20:15 am
Title: Library with all footprints
Post by: glatocha on June 30, 2013, 07:20:15 am
do you know, is there any library with just IC standard footprints?
I am making a lot of own components cause it is easy and fast. But each time I need to search through another libraries to find same package. Would be really easy to have library with just a standard footprints. Then you can simply copy to your library what you need.
Title: Re: Library with all footprints
Post by: kizzap on June 30, 2013, 01:21:56 pm
I generally just find the manufacturers footprint and hack together something with it...
-kizzap
Post by: senso on July 03, 2013, 10:34:22 pm
The are two with the standart libs package, called ref-packages and ref-packages-longpad, lots to choose from.
Post by: dumle29 on July 23, 2013, 10:54:48 pm
I like to make the footprints myself, and found that the people making datasheets like to make you work for your measurements, so I made this excel sheet.
It only does dip, and smd chips with pins on two sides (so no TQFP).
Might be of use :)
http://www.mediafire.com/view/mfybz6kic79bc2e/package_calculator.xlsx (http://www.mediafire.com/view/mfybz6kic79bc2e/package_calculator.xlsx)
