Author Topic: Looking for improvements before ordering.  (Read 5993 times)
Offline Mikey
  • Just hit 3rd!
    • captain-slow.dk
« on: February 26, 2015, 05:49:28 pm »
I made a new version of a PCB which had some stupid mistakes on it. On this new version I changed from some random Chinese relays, to some SMD ones from omron, LED's got moved, capacitors on the 3v3 rail got upgraded to 30 times the capacity as before, almost all traces got moved around and most of them made shorter, and the entire board got smaller... but have I overlooked something, or maybe someone got an idea on something that could be done better.
captain-slow.dk | 3D printing | CNC machining | Mechanical designs | Simple electronics
Offline Christopher
Re: Looking for improvements before ordering.
« Reply #1 on: February 27, 2015, 07:12:30 pm »
Looks good  :-+
I doubt it will matter much in your case, but routing of bulk & decoupling caps matter. Something like the attached pic is a preferred way of doing it: INTO the cap first, then OUT, rather than having the cap hanging off a trace.
Think in terms of current loops and you will be set
Offline Mikey
  • Just hit 3rd!
    • captain-slow.dk
« Reply #2 on: February 27, 2015, 07:29:02 pm »
In my case I will be dealing with current spikes up to 400mA in worst case, and a maximum of 4.8ms long, on my current board (which is even worse than this), it does not seem to be a big problem.
I tried to make them all like C1 and C2, but then I couldn't align the components that well, and my OCD took over and wanted me to put them the same way. :-DD
« Last Edit: February 27, 2015, 07:31:49 pm by Mikey »
Offline Mikey
  • Just hit 3rd!
    • captain-slow.dk
« Reply #3 on: February 27, 2015, 07:37:08 pm »
you must have spent some time rounding the traces.
what about clearances? would you consider having wider clearances?  :-// ... off hand it looks very small, but thats just me i think
That did take a bit time, yes.  8) But I like how they look, even when it makes no actual difference.
Clearance is set to 5mil, so you are right they are small. But it seems to be fine after the PCB is made too.
This is from the first version I made.
Online Monkeh
« Reply #4 on: February 27, 2015, 08:36:36 pm »
5mil is doable, but I see nothing in your layout which requires it.
Open it up to around 8mil, and expand your annular rings a bit as well. It can't hurt.
Offline Mikey
  • Just hit 3rd!
    • captain-slow.dk
« Reply #5 on: February 27, 2015, 10:13:15 pm »
This is with 8mil and the rings at 15mil. Went from 10 to 15 on the rings.
aaaand now I have to look at what is going on at the temperature sensor... they are overlapping now.
Online Monkeh
« Reply #6 on: February 28, 2015, 01:10:23 am »
Yeah, you don't need to go that high, especially on pads.
Leave the pads at about 10, make sure the vias are at least 7.
Offline Mikey
  • Just hit 3rd!
    • captain-slow.dk
« Reply #7 on: February 28, 2015, 12:49:22 pm »
Not sure if I am doing this right.
I changed the size here, the pads on the TMP36 sensor are still very close to each other.
Offline Mikey
  • Just hit 3rd!
    • captain-slow.dk
« Reply #8 on: February 28, 2015, 01:48:42 pm »
It is the component footprint, and they looks way too big on the board too.
On the device it looks okay, but when placed on the board they are getting bigger.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #9 on: February 28, 2015, 02:55:42 pm »
That big juicy ground pour...
Stitch it!
Plop down vias both sides of every trace, or group of traces (bus) that cuts across it.  Ideally, you always have traces crossing at right angles, when they do cross, so that at every intersection, you can put a via in each corner to stitch the grounds on all sides of those routes.  That's the basic idea.  Put vias every inch (20mm) or so along traces, and in corners, peninsulas, etc.
That TO-92 should really use a 0.1" pitch, or a staggered footprint.  If the part isn't sold with formed leads, it's a little bother to use that way, but it's far easier to use on the layout.
Seven Transistor Labs, LLC
Online Monkeh
« Reply #10 on: February 28, 2015, 03:26:02 pm »
Reduce the max restring to get those pads under control.
Or, as advised, use a staggered footprint and round pads.
Offline Mikey
  • Just hit 3rd!
    • captain-slow.dk
« Reply #11 on: March 02, 2015, 04:31:14 pm »
Tried to mess more around. And got all capacitors to be on the trace instead of hanging off it.
« Last Edit: March 02, 2015, 04:41:55 pm by Mikey »
