Author Topic: Multiple supplies with different names from same source - how?  (Read 4602 times)
Offline JohnnyMalariaTopic starter
    • Enlighten Scientific LLC
« on: December 13, 2020, 02:34:09 pm »
I have a design with 3 ICs that each require a +5V supply. However, the packages have different names for the supply pins: V+, VDD and VCC. I am using an 7805 to generate a regulated +5V. How can I connect the three different types of +5V? After hours of searching, all I've found is to use a zero ohm resistor or a short. That seems a bit kludgy and I'm sure I'm missing something. I'm just learning Eagle.
I've attached a section of the schematic to illustrate what I mean.
Thanks,
John.
« Last Edit: December 13, 2020, 02:35:43 pm by JohnnyMalaria »
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Multiple supplies with different names from same source - how?
« Reply #1 on: December 13, 2020, 02:36:05 pm »
You... can't rename the pins?  I don't get it.
Seven Transistor Labs, LLC
The following users thanked this post: JohnnyMalaria
« Reply #2 on: December 13, 2020, 02:42:40 pm »
The ICs are from managed libraries and so are read only. I'd have to create a copy and rename the pins. But I'd rather keep the names the manufacturer provides so I don't get confused months down the road or confuse someone else. It seems like I'd be getting into a bad habit which I'd like to avoid.
If just changing the pin name is pretty much what everyone does, then I'll do that.
Thanks.
Offline langwadt
« Reply #3 on: December 13, 2020, 02:46:47 pm »
wire the ICs supply pins to you 5V supply instead of relying on the terrible idea of hidden power pins
« Reply #4 on: December 13, 2020, 03:06:56 pm »
Then I run into another problem. One of the ICs is a 74ACT574N 8-bit flip/flop and the supply pins don't show up on the schematic. They are shown in the device view in the library, though (attached). That's why I created hidden supplies. I'm sure I'm missing something simple.
Offline Karel
« Reply #5 on: December 13, 2020, 03:25:37 pm »
In the end, the only good solution is to create your own devices (symbols and footprints).
Everything else creates frustration and error.
I understand that this is not what you want to hear. Creating your own libs takes considerable time at the beginning.
Offline langwadt
« Reply #6 on: December 13, 2020, 03:46:55 pm »
I haven't used Eagle in eons, but as far as remember, right click the symbol in the schematic and click "invoke" it'll let you place the power pins on the schematic
