Author Topic: Need help with creating a Board outline while in PCB of Eagle?  (Read 3097 times)
Offline TWTFKaye4Topic starter
« on: September 18, 2020, 10:36:07 pm »
HI I'm nubee to eagle and I"m makeing a small circuit board project.  I have gone right into the PCB layout part and I would like to know how to create a board out line for my board,, If anyone can please let me know How to do this I would be totally great full,,,  thank you,,   Terence.
Offline Quarlo Klobrigney
  • Country: pt
  • This Space For Rent
Re: Need help with creating a Board outline while in PCB of Eagle?
« Reply #1 on: September 18, 2020, 10:56:14 pm »
Draw it on layer 20, it should work.
Also, a bigger line width than 0 and one solid line from start to finish.
« Last Edit: September 18, 2020, 11:05:09 pm by Quarlo Klobrigney »
Voltage does not flow, nor does voltage go.
« Reply #2 on: September 19, 2020, 10:32:08 pm »
Hi Q,,
 How do you adjust the line Width? And access line 20?  thank you for your reply,,,  Terence.
  • Country: pt
« Reply #3 on: September 20, 2020, 02:50:52 am »
What version of Eagle are you using?
Usually one adjusts as one draws from the line width pull down size above. I think you need some basic "Using Eagle" videos on youtube.
