Author Topic: [Solved] PTH not connecting to inner layer pours  (Read 5973 times)
Offline StynoTopic starter
  • TÜV-geprüft
« on: June 09, 2021, 06:31:07 pm »
Anybody knows why plated through holes - that have the same net name as the inner layers pours - are not connected to the inner pours them when doing a ratsnest?
This is with a four layer board with a gnd and vcc plane on the two inner layers: (1+2*15+16) and using the Aisler 4-layer design rules. Any via with gnd or vcc is properly connected but none of the gnd/vcc pth’s. This happened with standard footprints like pinheaders but also with footprints I made myself, e.g. a Keystone AA battery holder.
I did not notice this during design (no DRC errors) and the Gerber review but only when the pcb’s came back and didn’t work...fortunately this is pretty easy to patch on a prototype this with some wires.
« Last Edit: June 10, 2021, 09:15:43 am by Styno »
  • TÜV-geprüft
Re: PTH not connecting to inner layer pours
« Reply #1 on: June 10, 2021, 09:15:18 am »
The problem happened because the selected DRU file was missing, placing a copy back solved it. It would be nice if Eagle gives an alert when it can't load the DRU file.
