Author Topic: Ripup the traces after applying the ratsnest command in Eagle  (Read 3767 times)
Offline rithi3
« on: December 18, 2012, 07:18:38 am »
How to ripup the traces of a net (Say want to delete all the Gnd net traces) after the ratsnest command applied?. I tried & couldn't delete the traces. Plz help me.Thanks!!!
Offline funk1980
Re: Ripup the traces after applying the ratsnest command in Eagle
« Reply #1 on: January 17, 2013, 08:29:23 pm »
You remove traces with the ripup command (or button). The actual airwires (yellow lines) are a direct result of the schematic the PCB is based on.
Offline oyvdahl
    • Build Electronic Circuits
« Reply #2 on: January 22, 2013, 12:59:12 pm »
As funk1980 says, use the ripup command.
You can specify a net as well if you's like: RIPUP GND
