Electronics => PCB/EDA/CAD => Eagle => Topic started by: rithi3 on December 18, 2012, 07:18:38 am
How to ripup the traces of a net (Say want to delete all the Gnd net traces) after the ratsnest command applied?. I tried & couldn't delete the traces. Plz help me.Thanks!!!
You remove traces with the ripup command (or button). The actual airwires (yellow lines) are a direct result of the schematic the PCB is based on.
As funk1980 says, use the ripup command.
You can specify a net as well if you's like: RIPUP GND
